GM guide plates
Old Oct 24, 2006 | 07:28 PM
bolek's Avatar
GM guide plates
I finally found out why my GM guide plates are wearing out) .
I replaced first set after about 10K miles (worn bad). .
I am running a second set of plates (4K miles) and again
all of them are showing wear. .
So recently I ordered my third set. And here is the thing,
even though they are the same plates ( 05 P ) they are
much darker in color( kind of brownish-not shiny ) than the first
two sets (light steel and shiny).
It turns these darker plates are hardened. A file will cut into the first
2 sets with ease. This one I can hardly scratch with the file and
the sound is completely different. They will go in as soon as possible. .
Looks to me like somebody let a big batch of unhardened plates
go through, if only I can get my hands on that person.
Old Oct 24, 2006 | 07:45 PM
wrd1972's Avatar
I have never seen the GM guide plates come pre-hardened. I have had seveal problems with them too so I hardened my own GM guideplates myself. Not even a smidge of wear like before.
Old Oct 24, 2006 | 08:49 PM
rpm4lalo's Avatar
I did not have good luck with the GM guideplates, they simple wear to quick. I use Isky Adjustables now.
Old Oct 24, 2006 | 09:34 PM
bolek's Avatar
I have a feeling that the new ones ( definately hardened ) will
not wear out any time soon.
Old Oct 24, 2006 | 09:38 PM
69gto96z's Avatar
Was it a different part number? Or did you just get unhardened ones before and these happened to be hardened?
Old Oct 24, 2006 | 11:18 PM
bolek's Avatar
Same part number.
Old Oct 24, 2006 | 11:37 PM
69gto96z's Avatar
Wow, thats weird. Maybe I will get lucky and get some hardened ones
Old Oct 24, 2006 | 11:51 PM
Daniel6718's Avatar
damn...hope i got good ones...havent cheked them in about 10k
Old Oct 25, 2006 | 02:28 AM
hvyss's Avatar
My GM guidleplates did the same thing. I did what rpm4lalo did and went with the Isky adjustables and no further problems.
HVY SS
Old Oct 25, 2006 | 08:07 PM
snakeatinZ's Avatar
HVY SS
Where can I pick these up at?
Steve
Old Oct 25, 2006 | 09:20 PM
ibanez6rg's Avatar
That's great to know.
Old Oct 25, 2006 | 09:45 PM
69gto96z's Avatar
Here is the Isky's at thunderracing.com. Also, thunderracing says that their GM guide plates are hardened.
http://www.thunderracing.com/catalog...vid=4&pcid=250
Old Oct 25, 2006 | 10:43 PM
yotaman96's Avatar
My first set were shiny and wore quickly. My new ones are darker and look to be hardened. Hopefully they will do better.
Old Oct 26, 2006 | 02:00 AM
sbs's Avatar
sbs
Thunderracing isn't saying anything. That's the GM part description.
Old Oct 26, 2006 | 08:04 AM
rpm4lalo's Avatar
I got the Iskys from Summit, I adjusted them completely then put a tack weld to hold the 2 piece plates together.
