GM Coil
Old May 27, 2008 | 08:30 PM
z275plus's Avatar
Exclamation GM Coil
I noticed on the golen engine LT1 fact sheet for LT1 engines that they said the stock coil from the 96-97 F-Body was a good coil.
The problem is the 96-97 coil will not fit the 95 model. Is there anyway to get the 96-97 coil to work on the 95 model ?
How does the 95 coil stack up against the rest, 96-97 GM, MSD, ACCEL, ETC.
Old May 27, 2008 | 09:18 PM
Stl94LT1's Avatar
Your 95 coil will work just fine.
Old May 27, 2008 | 09:49 PM
If you want a little better coil for your 1995, get an MSD, Accel, etc. It would be easier than trying to adapt the later GM coil.
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
68camaroboltz
Oct 5, 2015 01:46 PM
Z Power
Sep 19, 2015 11:19 PM
