gm 847 woes
Old Jun 14, 2004 | 12:31 AM
n20ta2's Avatar
gm 847 woes
I installed a gm 847 last week and a fresh tune to match,also installed a t-350 at the same time.Problem is when settling down to idle after driving it wants to stall untill completly stopped,then a blip of the throttle cleans it up and it idles fine.It has a 3500 stall converter in it and also had the tranny programmed out so that shouldnt be it ,any ideas? It worked fine with my cc305 and 4l60e before the swap.Also forgot to mention exhaust is rubbing crossmember and will be fixed tommorow could this be a cause ?
Old Jun 14, 2004 | 01:03 AM
SS RRR's Avatar
Did you get it dyno tuned or a mail order tune?
It's possible the PCM will just have to relearn. When I had my LPE 211/219 cam after I installed Hooker LT's and would disconnect the PCM I would have the same problem. It took about a weeks worth of start cycles for the PCM to finally learn where the idle was.
Old Jun 14, 2004 | 08:36 AM
got_hp?'s Avatar
glad to see you got it in already bob..............its definetly the tuning.....the 847 is too big, and too different than you old cam for the same tuning to work........you really need to set her up for some dyno tuning time.........not only will it fix the idle problem, but it youll gain quite a bit of power.
our local shop/club just off of adamo drive in tampa http://www.revxtreme.com/forums/ just got a brand new dynojet, so you can get tuned there.
Old Jun 14, 2004 | 09:20 AM
xxsaint69x's Avatar
how do u people think a dyno tune will improve anything with driving the car on the street? As far as i am concerned DYNO tune is for tuning WOT not part throttle
The problem you are describing happens too all of us with big cams. It will go away once the PCM learns to deal with it. It usualy takes about a day of driving. Also as weird as this may sound your alternator might be going out. If your problem doesnt go away by iteslf after driving around for a while, you might want to get your alternator checked out.
Marcin
Old Jun 14, 2004 | 09:45 AM
LWillmann's Avatar
Marcin
You can use a dyno to work with the part throttle tuning. No one ever said you HAD to run just WOT on a dyno. You can get all of the tuning done at one time, in one place.
Old Jun 14, 2004 | 10:30 AM
got_hp?'s Avatar
exactly..........a full dyno tuning package includes much more than just WOT tuning........a good tuner will help your idle, get rid of surging, and improve part throttle response as well.
Formula Steve
Sep 19, 2023 08:31 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
badblackta
Mar 10, 2004 09:18 AM
Camaro_Maniac63
Feb 9, 2004 04:26 PM
Mystic97Z
Dec 16, 2003 05:00 PM
