GM 847 Degree Questions
I am installing the GM 847 cam and have never degreed a cam before. I purchased a Comp Cams degree kit and am following the instrutions included with it. I degreed the cam with the heads on the car using the intake centerline method and measured 106 degrees. I have looked at the cam card and don't understand how I relate my degre measurement to the specs on the cam card. I would appreciate any help anyone can provide.
Thanks,
Loren
Thanks,
Loren
Re: GM 847 Degree Questions
Hey Man did you ever get that cam degree'd? Just wondering if it is any different that installing "straight up" I might have to give you a call sometime on that to see how its done. Did you and the rest of the guys go out to Memorial last night? I was sick to my stomach last night! No fun!
Later
Les
Later
Les
Yup, degreed the cam. Fortunately, it was right on and didn't require any bushings. I am happy to help you out when you are ready to do yours. Yup, went to memorial and it was a no-loss evening
kev93z28
Aug 19, 2002 12:48 AM
