gm 847
Old Jun 22, 2004 | 05:14 PM
KillWhitey's Avatar
gm 847
What kind of power will i be looking at with a gm 847 cam and a good tune.
Old Jun 22, 2004 | 05:15 PM
KillWhitey's Avatar
right now my car is mostly stock. i have the free mods done and the cat is gone
Old Jun 22, 2004 | 05:23 PM
disco192's Avatar
Get new heads before you go with a cam that big.
Old Jun 22, 2004 | 05:28 PM
KillWhitey's Avatar
what cam do you recomend for stock heads? i already have the comp cams .488 .488 with a 114 lsa but i have a leaky timing chain cover and was going to upgrade while i was in there
Old Jun 22, 2004 | 05:39 PM
disco192's Avatar
Id look at the GM846 cam, its a sweet little cam. Its alot like the CC305, but has a tad bit more intake duration and exhaust lift. Its also ground on a 112.
There are alot of cams out there, but the 847 is a huge cam.
Old Jun 23, 2004 | 08:17 AM
WS Sick's Avatar
I have the 847, but in a 383 with 11 to 1 compression. it has a lovely lope in my motor and makes power as high as I want (6500). I would not reccomend this cam for a stock LT1 unless the person can put up with the surging, loping, and lack of power below 3000 rpm. Add some nice flowing heads and some compression and the story changes though, but its still a big cam for a daily street driven car.
Old Jun 23, 2004 | 09:17 AM
got_hp?'s Avatar
the 847 is a fine cam for stock heads.....its certainly not too big........however, you should definetly get the major bolton mods (headers, exhaust, etc) before putting in the cam.
and all those problems you mentioned are due to lack of good tuning.......a skilled tuner can have the car running smooth with no probs.
of course its going to work better with ported heads.........but all cams will.........might as well go big now, and then get the ported heads later when you can afford it.
and btw.......since no one actually tried to answer your question...........people with stock heads and boltons usually dyno around 350rwhp with the GM847.
Old Jun 24, 2004 | 01:59 PM
KillWhitey's Avatar
Thanks for the info. exactly what i wanted to know
Old Jun 24, 2004 | 02:32 PM
besz28's Avatar
yes do headers before you even think about a cam.good luck
Old Jun 24, 2004 | 11:58 PM
KillWhitey's Avatar
I am about to order the pacesetter lt's. how much gain do you think i will see with the cam that i already have?
Old Jun 25, 2004 | 12:27 AM
bunker's Avatar
the GM847 I would consider a small cam compared to what I have it barely ever surged unless I was stupid in driving, pulled from 2k all the way to 7k no probs.
Old Jun 25, 2004 | 09:25 AM
got_hp?'s Avatar
20-30 hp probably.........you should definetly feel the difference.......just make sure you get an LT4 knock module............and youll notice even more difference if you get the car tuned properly after.
Old Jun 25, 2004 | 11:26 AM
FireAm94's Avatar
Here comes the LT4 knock module debate....about the LT4 module being designed for an LT4 knock sensor.
Joe
Old Jun 25, 2004 | 11:52 AM
KillWhitey's Avatar
i have never heard that debate. so lets hear it
Old Jun 25, 2004 | 12:04 PM
bunker's Avatar
No jsut search for it, all I know is its a little less sensitive to knock but its still pretty darn sensitive, hence why my KR table is zeroed out.
