GLOWING exhaust manifolds
Old Jan 21, 2004 | 03:25 PM
transxtreme's Avatar
OK, my buddy just bought a 97 Z28 with the LT1. the car only has like 36 k miles on it and its the defintion of mint. He has had it for about 2 months now using it as a daily driver. With no warning his car just took a dump, BOTH the exhuast manifolds awere glowing red, and he cant get over 20 mph with the pedal all the way to the floor. Hes pissed and the car was never beaten on. We checked the voltage at all the injectors and it checked out all good. Any ideas. I dont know LT1s but maybe the fp is messed up or a sensor that is causing the computer to dump extra fuel into the cylanders. No fuses are blown and the exhaust was never touched so nothing i could think of, Any ideas please. He has to get to school tomorrow, thanks
Old Jan 21, 2004 | 03:28 PM
scoobysnax83's Avatar
well.....sounds like fuel to me. Replace the filter and it should help.
BTW: glowing manifolds mean lean not rich....
Old Jan 21, 2004 | 03:50 PM
1fast95Z's Avatar
Sounds like a lean condition with clogged cats.
Old Jan 21, 2004 | 03:52 PM
maayybe, but Cats don't usually go, "well I'm gonna clog today." They will slowly kill performance.
Old Jan 21, 2004 | 04:00 PM
1fast95Z's Avatar
Very true, but, catalytic monoliths have been known to break loose and stop up exhaust flow. He could verify that by getting under the car and tapping on the converter itself to see if there is any rattling. I would suspect a lean condition caused by a bad fuel pump or injector issue.
Old Jan 21, 2004 | 04:07 PM
36000 miles is kinda soon for a cat to clog. Filter is cheap and easy as well as routine maintenance that should be done anyhow.
Old Jan 21, 2004 | 04:08 PM
ATMINF's Avatar
It sounds like you are running lean, as the others stated the O2 sensors are probably going south and yor CATS are breaking up and causing the exhaust to get clogged. Good Luck
Old Jan 21, 2004 | 04:10 PM
crawlin z28's Avatar
my friend has a 95 z and he had the same problem and it ended up being a clogged cat.......
Will84's Avatar
A 97 with only 36k has been sitting a lot. It probably had Schitt settled in the gas tank... which is now clogging the filter. I'd change that first. Also run some cleaner through.
Oy vey
Old Jan 21, 2004 | 04:29 PM
z28s's Avatar
id check the temperature before and after the cats to see if their clogged before changing anything, my cat fell apart and totally blocked off my exhaust i had the same problems..
Old Jan 21, 2004 | 04:33 PM
gut the fugger change the filter and call it a day
Old Jan 21, 2004 | 05:13 PM
Camaro_Guru16NY's Avatar
I secomd that!!!!
-John
Old Jan 21, 2004 | 05:42 PM
marshall93z's Avatar
when my cat clogged it was running fine that morning and i noticed throughout the day it felt like it was getting sluggish. by the time i got it home i could barely pull up the driveway.
couldnt even hardly hear the exhaust it was so stopped up!
Old Jan 21, 2004 | 05:58 PM
thanks
Alright, im goin over there now and we are going to change the fuel filter, and 02 sensors and if that isnt it then we are going to take off the cat thanks and ill let u guys know wat happens
