glaze on windshield
Old May 1, 2003 | 11:13 PM
Azimiut's Avatar
glaze on windshield
I just noticed this the other day, on mostly the drivers side of the car there is like a glaze on the bottom of the windshield on the inside. looks like steam, but it does not go away. there is a little on the the pass. side also. is my heater core leaking? same kinda thing happened in my buddy's 5.0, but you could smell it. any help would be aprreciated. thanks
Old May 1, 2003 | 11:54 PM
95BlackTA's Avatar
Hmm...If the heater core is leaking from the tubing going into the firewall(so leaking into the engine bay)..it will drop coolant onto the headers and exhuast...causeing white smoke to come up on the passenger side. I dont know what would happen if the actaul heater core is leaking inside the dash..never had that problem. Heatercore is on pass, not driver side.
What does "glaze" mean. You mean like white substance on the inside of the glass? Or actual steam?
Old May 2, 2003 | 02:07 PM
Azimiut's Avatar
it looks like steam. but it is like a residue, has an oily feel to it. the way it appears on the window is like to was blown onto the window, if you know what i mean. like it came from an air vent, but there is no vent there. I am totally lost as to what it could be.
Old May 2, 2003 | 02:41 PM
BackInBlackZ28's Avatar
Armorall overspray?
Old May 2, 2003 | 02:52 PM
snksknr94's Avatar
Don't worry about it, mine does it to. If you put a dash mat on the car it helps a lot. All it is, is residue from our giant dash boards. Since it is so warm here most of the time the plastic sweats, causing the foggy looking stuff on the bottom of the windshield. If your heater core broke in the car the passanger side floor board would be soaked with coolant.
EDIT: At the dealership I work for all the Cavaliers and a lot of the S10's have the same build up on the windows. It is becasue they just sit out in the sun all sealed up because nobody ever buys them or takes them on test drives. During the summer I usually have to clean the inside of the windows on them so you can see out, if somebody actually does want to drive one.
Old May 2, 2003 | 03:36 PM
Azimiut's Avatar
sweet. no worries. I get paranoid when something happens that I cannot expain or have never seen b4
Old May 2, 2003 | 03:39 PM
faded93bird's Avatar
mine dose the same thing just wipe it off with some windex when it gets too bad
Old May 2, 2003 | 03:47 PM
godofdragons's Avatar
mine is doing the same thing on the back window, explain that
AviatorDave
Dec 19, 2016 06:35 PM
Henson071
Sep 18, 2015 04:01 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Aug 5, 2015 08:35 AM
Henson071
Aug 4, 2015 09:32 AM
