"Ghost Turbo"
Old Apr 29, 2006 | 09:08 AM
Heatmaker's Avatar
Advanced Member
"Ghost Turbo"
I'm trying to figure out what it is, and where it's comming from. But every time I get on my Car and red line it around 6200 RPMs my car makes this Turbo type blow off sound... you here this noticable Tsssssssttt!!! When you shift the gears. It sounds pretty cool, but jsut what in the hell is it? So far it sounds like.... Raaaaaaaaaaarrr Tssssstttt (2nd gear) rooooaaaaaarrrrrr Tssstt! (3rd gear) Raaaaaaarrrrrrrr Tssssssttt! (4th gear)
anyone know?
Idon't want to suddently hear ... rrrroooaarrr Tsssst! then POW!!! and my engine parts all over the place.
Old Apr 29, 2006 | 10:36 AM
94zrag's Avatar
Re: "Ghost Turbo"
Any chance you have a K&N intake? My buddy just put one on his pick-up, and it does the same thing. It does sound kinda cool though.
Old Apr 29, 2006 | 11:16 AM
Drowned's Avatar
Re: "Ghost Turbo"
It's the CAI... mine started doing that after I installed a CAI...
Old Apr 29, 2006 | 11:19 AM
Dave '97 Z28 M6's Avatar
Re: "Ghost Turbo"
Could it be a bit of slippage of the accesory belt? That's pretty common - when you shift into a higher gear, the belt is suddenly going a lot slower than the accessories. All the accessories have momentum, so the belt slips a little bit until the speeds match.
Old Apr 29, 2006 | 06:06 PM
FuryZ28's Avatar
Re: "Ghost Turbo"
Have you removed the intake silencer? I'd say between that and a CAI, that'd be what you're hearing.
Old Apr 29, 2006 | 08:58 PM
matt formula's Avatar
Re: "Ghost Turbo"
I've got the same problem with mine, still trying to figure out where it is coming from, my buddy thinks it coming from the tranny ( I hope not)
Old Apr 29, 2006 | 09:06 PM
Sparkz28ss's Avatar
Re: "Ghost Turbo"
.....its the air rushing into the TB that makes the sound....its not going to hurt anything .....even with the donky D thing on there its still going to make noise
Old Apr 29, 2006 | 10:04 PM
jamilz28's Avatar
Re: "Ghost Turbo"
what can u use to plug the silencer???
Old Apr 29, 2006 | 10:38 PM
Spitfire557's Avatar
Re: "Ghost Turbo"
Your best bet is to cut out a block of wood and put it in there, then clamp it down with a band clamp. I've even heard some people say the caps to deodarant bottles and shampoo bottles fitting on perfectly.
ChrisFrez
Dec 7, 2014 06:01 PM
ChrisFrez
Nov 30, 2014 08:41 AM
ChrisFrez
Nov 23, 2014 10:33 AM
Zack
Sep 21, 2003 08:41 PM
