getting the t-stat out.....
Old Jun 11, 2006 | 10:29 AM
GT KILLER's Avatar
how do i get the damn thing out? is there a trick or something?
Old Jun 11, 2006 | 11:22 AM
Dave89IROC's Avatar
Re: getting the t-stat out.....
remove the outlet and pull it out, if it is stuck, pry it out with a screwdriver
Old Jun 11, 2006 | 01:36 PM
fredmr39's Avatar
pull straight up with plyers (protect with a rag if you wish)
be prepared for coolant to fly out as well - in that case, prying is best, just risk damaging more IMO? idk
but, no trickery
Old Jun 11, 2006 | 03:11 PM
GT KILLER's Avatar
Thanks guys, but I got it a few hours ago, lol. I was panicking because when I took the water pump housing off, coolant went everywhere (I felt like killing myself) but as it turns out the opti is ok because after I finished everything and put it back together, the car idled fine and I took it for a drive and everything was kosher.
I did end up having to just work at it with a screwdriver....it was a bitch but it came out. No coolant came out when I took the actual T-stat out, it probably all came out already from when I took the housing off It just ran down the front of the waterpump and hit the driveway....didn't get near the opti or any electronics. Which is very good. And I got most of it with the rags I had there, so I minimized the flood majorly.
Old Jun 11, 2006 | 03:22 PM
fredmr39's Avatar
I remember when I did mine I had rags EVERYWHERE even NEAR the opti..............then, when either the housing or t-stat came out, magically all the coolant found its way to the opti.....to this day I still do not know how. it ran fine after tho > : - >
Old Jun 11, 2006 | 03:41 PM
GT KILLER's Avatar
I did have rags packed in there, but I had to kinda pry the housing off so I needed to take the rags away to make room to work.......I wasn't expecting it to come off so quickly otherwise I would've packed the rags back in there when I started to get it to come off.
I think we should both count our blessings!
tdigger9899
Sep 7, 2015 10:56 AM
Stumper66
Nov 21, 2003 12:40 AM
Got-LT1?
Jul 14, 2003 06:06 PM
LT194
May 6, 2003 07:02 AM
