Getting a set of roller rockers...
Old Jun 11, 2005 | 10:41 PM
Huntr1117's Avatar
Question Getting a set of roller rockers...
Getting a set of roller rockers and was wondering which ones I should get. Are the GMPP 1.6's any good or what? A friend of mine was going to sell me a set and I was wondering if they were worth the money? Also, do I need to change any parts when installing a set or will my stock springs,...etc work fine? I was also planning on 355 LE1 setup in the future when I get some extra cash. I know that I need to take this under consideration when getting new parts so that I don't need to replace them later. Any suggestions?
Old Jun 12, 2005 | 12:47 AM
Bud M's Avatar
Re: Getting a set of roller rockers...
The GMPP rockers are ok (I'm assuming they are the ones in the hotrcam kit) but upgrade the springs. For a stock cam and 1.6 rockers you can use LT4 springs.
Old Jun 12, 2005 | 02:54 AM
Compstall's Avatar
The GMPP rockers are actually Crane rockers from what I've read.
Old Jun 12, 2005 | 08:36 AM
97pontta's Avatar
I have Crane self aligning rockers which are the same as the GMPP ones. They are OK but are alittle noisy, If I were to do it agian I would go with comps and use guide plates with some hardened pushrods. The comps are really nice units.
Old Jun 12, 2005 | 09:06 AM
Huntr1117's Avatar
If I were to do a 355 Le1 setup would the GMPP 1.6's hold up?
Old Jun 12, 2005 | 09:46 AM
Mindgame's Avatar
What does Lloyd recommend with his setup?
The Comp Pro Mags would probably be my first choice with this cam but I'd go with whatever Lloyd recommends.
-Mindgame
Old Jun 12, 2005 | 10:22 AM
CreatiVe2's Avatar
Comp pro mag 1.6:1 NSA with 7.2" hardened pushrods and guideplates =-)
at least thats what he told me for my (future) LE1 setup =-)
Old Jun 12, 2005 | 01:48 PM
Huntr1117's Avatar
Ok, planning on getting a set of Comp pro mags 1.6 NSA 7/16 stud. What do I need to change besides getting a set of 7.2 hardened pushrods, 7/16 studs, and a set of GM guide plates? Can I use my stock springs? I'm already over on my budget.
Old Jun 12, 2005 | 03:25 PM
Bersaglieri's Avatar
At least LT4 Spring set, now if you get a LE1 cam youll need bigger ones, but those will do until you get the H/C package. I got my LT4 springs, locks, etc for $40 shipped. BTW I used 7.195 size pushrods that Summit said wouldnt work on an LT1, but they work great. Comp's hardened ones 7608-16 I think.
-Dustin-
Old Jun 12, 2005 | 04:25 PM
Huntr1117's Avatar
So my stock springs and retainers won't work
Old Jun 12, 2005 | 04:46 PM
CreatiVe2's Avatar
no, usually with ANY cam upgrade its not recomended to go with stock RR's or springs... just picture it as a CHEAP insurance as opposed to a repair or a new engine that would be needed if something went wrong.
Old Jun 12, 2005 | 04:50 PM
MentalCaseOne's Avatar
I went with the Scorpions 1.7 and Beehive Springs. Installed them last december and got a very noticeable power increase.
Marvin
Old Jun 12, 2005 | 08:07 PM
Huntr1117's Avatar
I'm not installing a cam rightnow. I'm just replacing the lifters. I was just wondering if I could use the comp pro mags with my stock springs.
Old Jun 12, 2005 | 08:14 PM
Robs97Z28's Avatar
you stated you are going to use comp pro mags 1.6rr. The stock rr are 1.5. when you increase the lift by switching to a longer rocker arm, you should replace the springs. this will aviod the chance of coil bind.
Old Jun 12, 2005 | 08:22 PM
Huntr1117's Avatar
So I could use the Lt4 springs right?
