getting jethot longtubes what else?
Old Jul 9, 2003 | 01:26 PM
lt4 fd's Avatar
Im ordering them today and was wondering what else i need to get the car running right that doesnt come with them? I have an LT4 knock module thats about all I can think of really...
Old Jul 9, 2003 | 01:31 PM
Blue96z28's Avatar
There are some little things you might want to get...
gaskets(the ones that come w/ the headers suck)
bolts(stage 8 locking may be worth it)
new o2's in the front
o2 sims in the back(depending on year of course)
o2 extendes(depending on how lazy you are)
Old Jul 9, 2003 | 01:33 PM
EviLBoX's Avatar
You'll also need a y-pipe or have one custom made. Your car is OBDI, so you won't need O2 sims. The rest of what's listed above looks good.
Old Jul 9, 2003 | 01:42 PM
got_hp?'s Avatar
im halfway through my install right now.......heres what i got
necessary:
felpro header gaskets (1406 i think from summit)
collector gaskets (summit)
LT4 Knock module (from jason chromer)
custom y-pipe
stage8 locking header bolts (from speed Inc)
optional:
new autolite plugs (why reuse plugs when theyre so cheap)
EGR blockoff plate (from angie at thunder racing)
24" O2 extensions (from MASC performance)
modified PCM via pcmforless (from MASC)
new moroso plug wires (from MASC)
DEI aluminized heat sleeves to protect plug wires (summit, only $7 for set of 4!)
i think that was it.
Old Jul 9, 2003 | 02:40 PM
lt4 fd's Avatar
Cool so ill need to get new o2 sensors? Also I am undecided if im gonna use nitrous or not so as far as plugs go if I got TR6 plugs for the nitrous how would that effect things off the nitrous or even if i ended never using nitrous and selling it and just getting 4.10's put in?
Old Jul 9, 2003 | 02:56 PM
Blue96z28's Avatar
If you use the nitrous, you'll want the nitrous plugs, but since you'll have headers it shouldnt be to hard to change to the other plugs later when/if you put the nitrous on it....i would go with the stock heat range plugs now(dont get bosch...dont ask).......then uograde later if you so choose, you'll loose a little hp from the colder range plugs but not drastic though.
CamaroBoy96Z28's Avatar
The Jet-Hots come with bolts, header gaskets, and collector gaskets. I used the gaskets and bought ARP header bolts. They are still very tight and have been running with them for about 2 weeks. You'll need 2 O2 extensions. I'm still on stock O2s and alright, its not necessary to change them yet but its up to you. I will be changing mine at the end of this year. I used NGK TR-55s with taylor OVC wires and looms (kit from Thunder Racing). I'm not familiar with N20 and the TR6s so I cant help you there but people dont ride the juice every single time they're driving the car so I'd assume you would be perfectly fine even if you never used the juice.
Old Jul 9, 2003 | 03:00 PM
lt4 fd's Avatar
Ok sweetness, Ill check out how much all this is gonna cost me and post back if I have anymore questions, thanks for all the responses or ide be lost, thank my lucky stars for the internet!
Old Jul 9, 2003 | 03:10 PM
coletrickle350's Avatar
Are the tr-55's colder than the stock plugs?
I used to run a blower and ran the tr-6 plugs now i'm N/A and i'm still runin them.
Any probs with that?
Thanks Mike
Old Jul 9, 2003 | 03:13 PM
Blue96z28's Avatar
the tr55's are stock heat range......if you switched back to the stock heat range blugs fromt the 6's you would see a slight slight hp increase, maybe a little MPG, but definetely not huge by any means or SOTP.
Old Jul 9, 2003 | 03:16 PM
Thanks Mike
TR-55s are stock gap, stock heat range. Running TR-6s shouldnt be bad. I'd prefer the best plug setup adapted to my needs which is the TR-55 stock everything, but the TR-6 shouldnt hurt I would think unless someone proves me wrong.
Old Jul 9, 2003 | 03:19 PM
thanks guys
btw i always gap my own plugs, it seems that the car loves .050
Guess I'll stick with the tr6's aint done me wrong yet
Old Jul 9, 2003 | 11:33 PM
lt4 fd's Avatar
Hey anyone know exactly what header gastkets to use there are 1407 and 1406 that may work from summit, also what about header wrap it may keep the coating good for longer and reduce heat under the hood are there any downsides? and im gonna need 2 o2 extentions but what length should I get 12, 24, or 36? then just stage 8 locking header bolts, plugs wires and sleeves... How much are o2 sensors and how do I know if they need to be replaced my car runs fine BTW...
Old Jul 10, 2003 | 12:09 AM
2 24" o2 extensions. If your o2s are ok and car runs fine, dont worry about it. Dont fix it if it aint broke right?
Old Jul 11, 2003 | 01:41 PM
lt4 fd's Avatar
What gaskets do I use with these headers 1406 or 1407 from summit.
