Getting the Hub off
Old Jul 12, 2006 | 12:11 AM
Heatmaker's Avatar
Advanced Member
Getting the Hub off
This car is giving me more trouble than North Korea. What's a smooth way of getting the hub off?
Old Jul 12, 2006 | 02:51 AM
KWIK WS6's Avatar
From: Southern California, where do YOU live mutha****a?
Re: Getting the Hub off
I put a slide hammer in the center hole of the puller and banged it off. Did not hurt anything.
Old Jul 12, 2006 | 07:27 AM
The correct hub removal tool is like a regular damper remover, but it has a hardened rod that slides in the bolt hole for the center post of the puller to push against.
Old Jul 12, 2006 | 07:42 AM
wrd1972's Avatar
I dont think I would use a slide hammer for the hub on the crank, does not feel right.
Heavy duty 3 bolt puller and some PB blaster should work.
Old Jul 12, 2006 | 10:04 AM
Heatmaker's Avatar
Advanced Member
I got a Balancer puller? might that work? or should I take a trip to Napa?
Old Jul 12, 2006 | 10:33 AM
95LT1Z28's Avatar
If it is the one with 3 "ears" on top and one on the bottom with the threaded rod going through the center you are good to go!
Jeff
Old Jul 12, 2006 | 10:39 AM
atljar's Avatar
First make sure the center bolt is out, and/or a longer replacement is in its place.
Then use some type of puller mentioned above on it.
If that doesnt work, heat the thing up with a torch. Sometimes they are just stubborn. Only harm is needing new front main seal, and thats only a few bucks.
AviatorDave
Dec 19, 2016 06:35 PM
Boss002
Jan 20, 2016 12:17 PM
Boss002
Jul 24, 2015 10:47 AM
RallyRed701/2
Jul 20, 2015 11:18 AM
cyteone
Feb 7, 2015 06:04 PM
