Getting headers
Old Feb 28, 2003 | 07:49 AM
gh0st's Avatar
Getting headers
I'm going to be buying the Jet Hot headers for my car soon, but I'm wondering what I need for the install. I'm going to be using an offroad pipe so I was curious what I need to do with the o2 sensors...will I still be using them or would I get sims?? or would i have to buy extensions?? I have a 93z
Old Feb 28, 2003 | 08:34 AM
Blk94Z28LT1's Avatar
one thing you will need is alot of time and Patience. Headers are a pain. Worth doing, but a pain.
MEAN LT1's Avatar
You might want to do a search on this as someone just asked the same question a day or so ago. Your going to need some fel-pro header gaskets and depending or not if your going to block off you egr, your going to either make or get the block off plate from gm. You also might consider some stage 8 locking bolts for headers as well. You will also need some o2 extensions
Old Feb 28, 2003 | 08:39 AM
EviLBoX's Avatar
Yes you will need O2 sensors, they help adjust your air/fuel ratio. O2 sims are only for OBDII when you run no cats, they trick the computer into thinking the cats are working fine.
Old Feb 28, 2003 | 10:18 AM
gh0st's Avatar
thanks, I guess ill be ordering the bolts, gaskets and the plug for the egr, do they make different gaskets if im not going to be using the egr or are they all the same?? hehe and I just found out i get a lift to do this too
sherwinZ28
11
Aug 15, 2015 05:38 PM
colts0455
Jul 28, 2015 11:28 PM
jbc3
Jul 28, 2015 12:24 PM
Strick
Jul 14, 2015 07:28 AM
