general rebuild gaskets/bearings
Old May 18, 2005 | 09:16 PM
TransAmTONY's Avatar
I will be rebuilding my lt1 shortly for a 9.1:1 cr 383 turbo motor. I already have the crank, rods, pistons, rings, main caps, main bearings, rod bearings and all related gaskets and bolts for the lower end. Now i need the top end... is all i need camshaft bearings, head gaskets, intake gaskets? I will be re-using the stock heads and will be using local shops to aid in a cheap rebuild/mild port.
is there anyone out thre that sells all realted top-end rebuild parts/pieces.????
thanks guys,
Tony
Old May 18, 2005 | 09:18 PM
Bow94z's Avatar
Re: general rebuild gaskets/bearings
www.eportworks.com for heads/cam
Old May 18, 2005 | 09:21 PM
SoloExceptional's Avatar
I would seriously consider replacing the whole valve train short of the studs and push rods, they do get under a lot of stress.
Old May 18, 2005 | 10:17 PM
dover179's Avatar
thanks guys,
Tony
Your local parts store should have a head set, which has ALL the gaskets and seals for the top end of the motor. It's a bit pricey, but you could find out what all is in it and get them seperately or pick and choose what you need to save some cash.
cocopops
Cars Wanted
Feb 1, 2016 06:22 PM
Ks0209
Oct 1, 2015 07:32 AM
Bxlt1
Sep 29, 2015 03:18 PM
Z Power
Sep 19, 2015 11:19 PM
