gee... plug #8
Old Apr 13, 2007 | 07:56 PM
bombebomb's Avatar
gee... plug #8
ok iv been trying to get plug #8 out for 4 hours, how do I do it!
Old Apr 13, 2007 | 08:05 PM
mrseven's Avatar
There are 2 ways to get to the number 8 spark plug.
#1 - Drop the Y-pipe. Kind of a pain if the bolts are rusted on there real good
#2 - If you have kinda skinny arms, then you can pretty much wedge your hand past the exhaust manifolds and reach it that way.
You will have scrapes on your arm and your fingers will cramp many times , but eventually you can get to it. The hardest part is pulling off the spark plug wire boot.
And make sure you use di-electric grease on the spark plugs and boots! It will make it all the easier to get them off the next time
Old Apr 13, 2007 | 09:22 PM
twister19's Avatar
Remove the 2 starter bolts and move the starter aside.
Old Apr 13, 2007 | 09:41 PM
mrmint69's Avatar
Be ready to read the exhaust manifold serial number on your arm. That is one tight spot even if you have skinny arms.
Old Apr 13, 2007 | 10:05 PM
bombebomb's Avatar
Looks like ill have to drop the Y pipe, the boot as easy to get off, it "appears" the last owner of this car ignored changing the 2 hardest plugs, because they was all autolites but 1 (so far im asuming this last one is also some off brand)
Already tryed
Old Apr 13, 2007 | 10:17 PM
seawolf06's Avatar
Get LT's.
Old Apr 13, 2007 | 10:37 PM
MyWifesZ28's Avatar
I agree with twister, just unbolt and push the starter aside, slip on sparkplug socket, and slowly turn by wrench
Old Apr 13, 2007 | 10:38 PM
bombebomb's Avatar
Wrench or ratchet?
Old Apr 13, 2007 | 10:52 PM
97greenie's Avatar
I started changing my plugs tonight.I got to #s 1,3,5,7 fairly easy and after about 5 beers I decided to finish the job tomorrow.I'm glad that I now know what I've got to look forward to.damn!
Old Apr 13, 2007 | 11:00 PM
pyro719's Avatar
yup pull starter bolts move to side! The plugs on these cars are extremly hard! I installed my transmission in less time than it took to do plugs!
Old Apr 13, 2007 | 11:01 PM
MyWifesZ28's Avatar
nope, you heard right "wrench" If you can get a ratchet on there, good for you, I just did mine last month, this was how it was suggested to me, took about a half hour to replace (after pushing starter aside). Remember patience
Old Apr 13, 2007 | 11:15 PM
bombebomb's Avatar
Ok ill try a "wrench" tomarrow, no idea how im going to get a wrench to fit there, but ill try to go from under the car like you said.
Edit: word to the wise, if you try to use a ratchet, prepare for it NOT to work.
Old Apr 13, 2007 | 11:22 PM
pyro719's Avatar
I used a ratchet
Old Apr 14, 2007 | 12:09 AM
LTgun_94's Avatar
Best set-up i have used it a ratchet-wrench and a socket that is made to slip a wrench on the end..workd great for me but i also have headers and and o/r y-pipe.
Old Apr 14, 2007 | 03:06 AM
Jamon's Avatar
I've never cursed so much in my life today...
I had to change spark plugs TWICE.
I have pacesetter headers...8 took me about 2 minutes...now ask me about 5 though. I think I wanted to cry at one point. Especially the second time lol...
Today was NOT a good day.
