gears?
Old Sep 24, 2003 | 02:53 PM
z28marine's Avatar
gears?
Well, i plan on finally ordering my headers pretty soon, and i figured since im at it i might as well order gears too. I was wondering if the Thunder Racing complete gear package was worth the money.
http://www.thunderracing.com/index.c...ategoryid=1062
What gears would be best for Freeway use and street use? Not necessarily a daily driver, but from time to time it could be?
Old Sep 24, 2003 | 02:57 PM
Antz97ZNJ's Avatar
GM motive seem to be the best..you can get the install kit n gears probably cheaper then anywhere else @ jegs,summit,etc.
Old Sep 24, 2003 | 03:11 PM
InjectedSS's Avatar
yea get some genuine gm gears or just the gm motive replacement gears...
and you don't need that bearing kit unless you already broke your gear's and have lil metal shaving's floating in there.. otherwise your stock bearings will be fine to reuse! don't waste anymore money on that POS 10 bolt than you have to
Old Sep 24, 2003 | 03:47 PM
BUBBA's Avatar
4.10 OEM gears with Ratech solid shims. JMHO
If you go with anything other than the OEM or GM Motive, you might get excessive noise.JMHO
Old Sep 24, 2003 | 05:52 PM
z28marine's Avatar
So, i dont really need all the stuff they advertise? i know ill need the oil and stuff, but not the cover or the ratech kit? If there are no shavings in the oil, i should just get the gears, installation kit and oil? What size gears are stock?
Old Sep 24, 2003 | 06:02 PM
InjectedSS's Avatar
stock gears for autos are 3.23's some had 2.73's if you really have a ghetto model.. and M6's come with 3.42's...
Old Sep 24, 2003 | 06:06 PM
z28marine's Avatar
whats best for street, and freeway use? I know 4.10's were suggested but any other opinions? 4.10s seem seem to be on the other end of the table from 3.23s.
Old Sep 24, 2003 | 09:15 PM
DB75's Avatar
I bought one of the kits from ThunderRacing and think it's well worth it. Most guys will tell you to go with 3:73s for the A4 and 4:10s for the M6. I purchased a kit with 3:73s and still get about 20 miles to the gallon with a combination of city/highway driving. New bearings and seals are a wise choice and you might want to get a T/A rear girdle w/the stud kit. I know a lot of guys will tell you not to waste a lot of money on the 10 bolt but not everybody can afford a 12 bolt either. You either spend $2200 for the 12 or $500 for the kit. Either choice is a wise investment; it just depends on your financial situation.
Old Sep 24, 2003 | 09:34 PM
my94blackz's Avatar
I personally think 4.56's is a great choice, there isnt but a few hundered rpm's diff from the 4.10's and 5 mph. Up your shift points to 6500 and run 4.56's. Also i agree with motive
Zach
Old Sep 26, 2003 | 01:49 PM
z28marine's Avatar
alright cool, i have a t-56so ill probably go with the 4.10's... what can these do for 1/4 mile times? My goal is to pull on slightly modded LS1's...im also ordering ASM headers along with them..and eventually new cam, 1.6RR's and the whole setup in the next few months
Old Sep 26, 2003 | 03:18 PM
RamAir95TA's Avatar
Not all M6s came with 3.42s. 93s with the M28 and M29 gearbox came with 3.23s or 2.73s, respectively.
Old Sep 26, 2003 | 05:20 PM
z28marine's Avatar
well, whatver i have now, i still want to upgrade and get better ones..question still remains
Old Sep 26, 2003 | 05:36 PM
viperkiller's Avatar
i say 4:10. you run about 2200 rpm at 70. i have the a4, but a friend has the m6 we put 4:10's cai tunning brass cevlar clutch litttle ex.. work pulls ls1's pretty easy.
Old Sep 26, 2003 | 05:41 PM
jkipp84's Avatar
Here's a calculator you can use to find the ratio that you feel will best suit you.
Old Sep 26, 2003 | 06:38 PM
97LT1F-Body's Avatar
The Motive 4.10 kit from Thunderracing.com was a good investment for me. I have no problems and felt it was a great performance mod. Reminder that you will spin the **** out of your tires 1st thru 3rd easily. So get some traction to the rear with your upgrade.
