Gearing Question
You can put any gear ratio in the rear axle on your Z28, as long as its for a 7.5/7.625" 10-bolt. Then you need to make sure you have a 3-series "carrier".... If your car came with 2.73 gears, you don't, and you either need to pick up a new carier, or get a 3.73 gear set that is specifically made for a 2-series carrier.
Then of course, you need to program your PCM for the new gear ratio.
ChrisFrez
Feb 15, 2015 07:49 AM
ChrisFrez
Feb 1, 2015 08:26 AM
ChrisFrez
Jan 25, 2015 08:06 AM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 15, 2014 03:09 PM
