Gear Driven Timing
Old Oct 1, 2005 | 10:18 PM
1993Fast_Z's Avatar
Gear Driven Timing
Gear Driven Timing is not possible for the LT1 correct? because of the Opti...let me know, thanks
Old Oct 1, 2005 | 10:50 PM
96capricemgr's Avatar
Re: Gear Driven Timing
I wouldn't say not possible and the opti is not the thing that greatly complicates it.
Old Oct 1, 2005 | 11:10 PM
simple's Avatar
i always just thought it was because of the knock sensor?
you would just need a vented opti setup like when doing the cloyes true roller timing set
if you can use a cloyes true roller on a vented style opti with minor timing cover clearancing, why cant you run a gear drive for the same '87 up roller block?
Old Oct 1, 2005 | 11:33 PM
1racerdude's Avatar
They make a gear set that will work,but ya have to have a distributor with dual sync.One for the plugs and one for the injectors.They make that too.
Old Oct 2, 2005 | 07:43 AM
Knock sensors and water pump are two problems right odd the top of my head and all you would gain would be an ungodly amount of noise that will only be "cool" for a short time then you will hate it.
Old Oct 2, 2005 | 09:42 AM
simple's Avatar
why would you need a dual sync dist.?
do you have too have that setup when running a gear drive on say an L98 motor?
EDIT: and there is an option of silent gear drives
EWP solves the WP drive issue, like with the Cloyes true roller
Old Oct 2, 2005 | 10:28 AM
Didn't say there were not solutions to the issues just pointed out the main things that need addressing.
I have heard a few cars where the owners claimed to have gone with the quiet geardrives and they were still loud to me, then again a whole lot of BS gets thrown around at shows and races. Even if they can be quiet I am not particularly convinced them worthwhile.
Old Oct 2, 2005 | 10:38 AM
simple's Avatar
it is kind of 1982 Journey era lol
but i'm just trying too get too the root of why we cant use one when L98 cars can?
if we can use the same true roller timing set like they can, what makes the gear drive so much different
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Collector Car
Jan 5, 2015 10:58 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
