Ge-tech results!!!!!
Old Oct 28, 2003 | 11:46 PM
scottslt1z28's Avatar
I have a g-tech pro-competition meter
today i ran it twice on a very flat road...........(once one way and then once the other way........i did that to correct any leveling problems their might be......i.e. -- fast one way and slow the other)
anyways here are the results
FIRST RUN -- 13.574 @105.50
60ft -- 2.236
330 ft -- 5.870
1/8th -- 8.849 @84.7
1000 ft -- 11.411
0-60 -- 5.535
SECON RUN -- 13.633 @ 104.57
60ft -- 2.232
330 ft -- 5.883
1/8th -- 8.880 @84.42
1000 ft -- 11.454
0-60 -- 5.604
Now i have a 1997 Z28 A4 w/ 3:23 gears a cut-out and a k@n filter............these times dont seem right...............
anybody have any input??
It was very cool here today and i did make one pass one way and the second pass the other way............(which logically thinking should give you two times that if averaged together should give you a very accurate measurement of what your 1/4 miles time should be....................assuming that the ground is not very level)
anyways.........just wondering what you guys think.................anybody have any comments??????
Old Oct 28, 2003 | 11:53 PM
FacelessZ's Avatar
yea those times seem a big gratuitous...
Old Oct 28, 2003 | 11:56 PM
Black_Z28's Avatar
They seem a little quick for your car. But you never know. But I think they're a little quick for your 60ft times. It's a good start though.
Old Oct 29, 2003 | 12:12 AM
i agree...........i think they do seem very quick considering my car, but i was just curious on what others have experienced from it....................i mean maybe i have a freak......only the track will tell. Thanks for the input guys.............anyone else have any comments???
Old Oct 29, 2003 | 12:21 AM
Van5150's Avatar
Maybe the unit is generous.
But more importantly what you have there is a base line for making improvements on your car.
Run it once more and see if there is much of a difference. I would like to see the results of that.
Old Oct 29, 2003 | 12:29 AM
ill run it a couple more times tomorrow..............and i will get back to you all on what it said.....................(p.s. -- i will do the same procedure -- runing down one way and back the other way...........and i will tell yall the results......)
Any more input??
Scott
Old Oct 29, 2003 | 12:47 AM
Detroit808's Avatar
my gtech pro comp reads about 2-3 tenths faster than I'm actually running, and the mph are off by around 5mph. I did the same 2-way running method you did to compensate for any slope.
Old Oct 29, 2003 | 01:07 AM
93M29FOURMULA's Avatar
Those G-Techs are not worth crap! They are very inaccurate, I took mine to the track and when I ran a 14.9 (spun) it said I ran 14.3 and when I ran a 15.0 (bog) it said 15.46. High altitude sucks! Anyway if you don't have a perfect launch the times are way off. When I still had my 300ZX Twin Turbo (wrecked ) I dropped the clutch from 7000 out of curiosity and it said that I ran 8.2 at 160, then I put the car in second and dropped it from 3000 and it bogged a little but not too bad(no torque below 4) and it said 20.4 at 54 that alone showed me that there is no way that those are even close to accurate times. That was with a G-Tech Pro Comp, the $400 one.
Old Oct 29, 2003 | 01:18 AM
MentalCaseOne's Avatar
it said 20.4 at 54
Man that car sucked!!!
Jest Kidding. Ya know girls and boys.. I have always wondered how did the freaking G-tech knew when you went past the 60 foot mark and 1/4 mile mark. I mean is that Friggin thing using Satelite GPS to tell where the heck you are?? or is just simply reading the Gravity pull of the car and then timing it?
Marvin
Old Oct 29, 2003 | 04:49 AM
magius231's Avatar
the problem with the G-tech is if you get any wheelspin at all it throws the meter off...and typically anyone that uses one has plenty of wheelspin. For reference, mine tells me fairly constantly that I run a 14.2@101, yet my 0-60 time is 5.4 (no 60' time on mine),
Old Oct 29, 2003 | 09:47 AM
Black_Z28's Avatar
I find that really hard to believe.
Old Oct 29, 2003 | 11:13 AM
RealQuick's Avatar
You'll be lucky to hit 80mph in the 1/8th, nevermind 84mph.
Old Oct 29, 2003 | 12:17 PM
teke184's Avatar
make a few more runs as stated....
and for curiosity, cap the cutout and see what that does...:-)
Old Oct 29, 2003 | 11:00 PM
i only had time to make one run today................. it was a 13.77 @ 103.67
i will do more tomorrow and get back with yall on all the details
Scott
Old Oct 29, 2003 | 11:05 PM
NXz28's Avatar
i have the orignal $140 version of the gtech...i've done about 15-20 runs total at the track with it
most of the time it adds about 2-4mph depending on how much i spun its added as much as 6-8mph
its usually give or take .1-.3 off either faster or slower
out of all the runs i've made its never been correct with both et and trap as compared to the track ...
