gaskets for opti spark
I will be installing an opti spark and I still need to get the gaskets.
parts i have: opti, cap, rotor.
-I believe i will need a water pump gasket, opti gasket,.... anything else?
I searched a little but could not find much. If there is a write-up saying what is needed, a link would be sweet!
thanks,
andy
thanks,
andy
Is this on your 94 ? Here is a great link this guy knows his stuff.
http://shbox.com/page/index.html
How long should that seal last? And do you have a pic of just the seal, the reason I ask I did not replace my seal 35k on it and now I noticed that a little bit of oil dripping.
Yes, this is on my 94, the non- vented version
so, when changing the otpi you dont have to remove the timing cover but you do to change the seal. Is taking the timing cover off a hard job(just unbolt once water pump off? lower oil pan)? So, the only 2 gaskets i would NEED are the 2 water pump gaskets? and another for timing cover.
thanks,
andy
thanks,
andy
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
Thanks, 2tight.
I think there is a water pump seal and an optispark seal in the timing cover. I believe they can be replaced without removing the timing cover.
http://web.camaross.com/forums/showthread.php?t=493471
I'm going to be replacing my optispark and I'm considering doing some other stuff at the same time, which is why I was curious about what's necessary to remove the timing cover.
thanks,
andy
thanks,
andy
