gaskets for cam swap?
Old Apr 2, 2010 | 02:53 PM
mike 1972's Avatar
Yeah guys I'm looking at putting a CC305 cam in my formula and was wondering other than the normal waterpump,valve cover, intake, and timming chain cover gaskets is there any other gaskets I'm going to need? I'm going to loosen the oil pan and re tighten it down . Been doing this on 1st gens for years and never had a problem with doing it.
Old Apr 2, 2010 | 03:19 PM
n2ceptor's Avatar
www.thunderracing.com use to sell a complete kit for cam changes... Might check their site..
Old Apr 2, 2010 | 07:01 PM
craby's Avatar
make sure the front cover set has the shaft seals with it. do the front main while your at it. so long as the pan gasket is not hardened then you should be ok to reuse. dont forget to rvt the corners were the front cover meets the pan. the water pump seal can be a pain if u dont have a install tool. the seal is a double lipped one and if you dont use the install tool the inner seal/lip can invert and tear or undermine the outer lip. its a plastic cap that goes over the end of the drive shaft, looks like a really short marker cap and if you have a marker the right size you can make one by trimming it to fit.
Old Apr 3, 2010 | 06:57 AM
ChevalierSS's Avatar
I've always used the WP coupler to slide the seal over without any problems
chuyz28
Feb 19, 2015 12:50 AM
InfernalVortex
Jan 17, 2015 09:35 AM
chuyz28
Jan 15, 2015 04:14 PM
chuyz28
Nov 25, 2014 11:14 PM
