gaskets
I looked and looked and summitracing.com was the cheapest at $193
. If youre looking for a cheap gasket set, this is not the motor for you as i found it out also!! Good luck. BTW It is a speed pro kit but the box says fel pro.
Re: gaskets
I just bought that speed pro kit from Summit. The gaskets look good, especially the head gaskets. I think it's a good deal. It doesn't hurt to have a few spare gaskets on hand either. That kit comes with seals too: rear main oil seal, optispark cover seals, and viton valve seals.
WobblySausage
Oct 7, 2015 02:44 PM
