Gasket removal
Old Apr 5, 2007 | 04:34 PM
hysteria1's Avatar
Gasket removal
Is there any kind of trick or easy way to remove the seal behind the optispark? Im changing the optispark and the seal where it plugs into the cam seems to be leaking so I want to replace it as well. Im having trouble removing the seal and need to know if there is some trick that im missing. I don't have a gasket remover so this may be making the process more difficult...
Old Apr 5, 2007 | 04:45 PM
WS Sick's Avatar
Well depending on which model year you have, the earlier (93-94s) are easy to replace just pop out the old one with a screwdriver (opti is off of course), clean the surface, install new one and reinstall shaft and opti ,(lube seal surface before).
On the 95 up cars the seal is a little harder to get out but still prys out , (easy ier with some channel locks, just grab twist and pry) its easier with a seal installer but a short 2 by 4 laid accross the seal and a hammer are pretty easy as well.
Old Apr 5, 2007 | 04:57 PM
hysteria1's Avatar
sorry, forgot to mention its a 95. I was afraid of tearing something up by using channels and muscling it out. If thats what you have to do then I'll pry away I guess.
Old Apr 5, 2007 | 08:08 PM
Z28LT1_Just_Nasty's Avatar
Where did you get your seal? I have to do the same
Old Apr 5, 2007 | 10:45 PM
hysteria1's Avatar
I checked all around my area (Napa, advanced auto) no one carried one or could even find where to order it. (Most of the people I had talked to at the stores didn't know what an optispark was or any clue of what I was talking about) I ended up getting the gm part number and my local autozone was able to order one that way. I've also seen ONE on ebay for my year vehicle. The GM part number is 12552428 I believe if that helps you. gl
Old Apr 6, 2007 | 12:35 PM
hysteria1's Avatar
Anymore ideas on getting this thing out??
Old Apr 6, 2007 | 01:09 PM
Personally bro I'm just gonna just try to pry it out myself maybe with some pliers. Just gotta make sure you don't gouge anything or put cuts into the metal.
Old Apr 6, 2007 | 01:40 PM
hysteria1's Avatar
Let me know how it goes. Im just having a really tough time with mine and I don't want to over do it. Afraid of tearing it up too much...
Old Apr 6, 2007 | 05:02 PM
salty's Avatar
If you fiddle with for awhile, it will come out. If you have a seal puller, that will help. Once the metal part of the seal bends a little, removal is easy.
Old Apr 7, 2007 | 11:01 AM
hysteria1's Avatar
got it out and new one in. Now on to putting everything back together...
Old Apr 7, 2007 | 11:20 AM
Originally Posted by hysteria1
...(Most of the people I had talked to at the stores didn't know what an optispark was or any clue of what I was talking about) ...
That is because optispark is a nickname. It's real name is the distributor.
Old Apr 7, 2007 | 11:22 AM
Dave89IROC's Avatar
bingo
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
warmeck
May 1, 2015 11:30 AM
4586
Apr 29, 2015 01:43 PM
Queens94z28
Dec 20, 2014 09:11 PM
