Gasket removal...
Old Nov 18, 2004 | 05:51 PM
Myxtreme1's Avatar
Gasket removal...
How do I get these things off?! I mean the hard plastic-like ones. Like the ones on the timing cover and the throttle body. I am afraid I am going to goudge the surface of these things. What a pain. Any info will be very appreciated. Thanks!
Old Nov 18, 2004 | 06:24 PM
ibanez6rg's Avatar
Re: Gasket removal...
Razor blade, perhaps?
Old Nov 18, 2004 | 06:34 PM
1 Nasty Bird's Avatar
you can gasket remover spray, spray it on, let sit for a few minutes and itll practically fall off by then usually. Sometimes youll need a lil more scraping and more spray but the stuff works great! Just watch the overspray!!! Thats some nasty stuff to be melting gaskets!
Old Nov 18, 2004 | 06:37 PM
94 CAMRO Z28's Avatar
Yea get some gasket remover spray. Usually you can spray it on, let it sit for a couple min. and then just wipe/scrape off the gasket. On real stubborn gaskets, you may have to do this process several times before getting all of the material off.
Aaron
Old Nov 18, 2004 | 11:46 PM
y5e06's Avatar
Man, I don't know. I've used the gasket spray on those gaskets you're referring to. Those ones are a b!^@&!!! The spray really didn't soften them up that much. sure as heck didn't just fall off. Still required quite a bit of work. I used the Permatex brand stuff too. You just need an assortment of scrapers. A razor blade scraper and maybe some chisel type scrapers. Of course, be very careful not to gouge the aluminum.
Old Nov 19, 2004 | 07:49 AM
Myxtreme1's Avatar
Yeah the spray didn't do much for these
and I feel like I was goudging the surface.
Old Nov 19, 2004 | 10:49 AM
1stz28's Avatar
A wire wheel on a grinder has always worked for me.
Old Nov 19, 2004 | 12:14 PM
Myxtreme1's Avatar
Will that scar up the aluminum?
magman
Apr 15, 2016 03:08 AM
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
pepon214tx
Sep 20, 2015 04:48 PM
