Gasket for oil filter adapter?
Old Aug 11, 2002 | 09:50 PM
97 RedSS's Avatar
Post Gasket for oil filter adapter?
Took the oil cooler off while Im replacing the motor and I was wondering if the oil filter adapter that screws into the block(i had to pick up 2 bolts from GM for the cars that dont have the oil cooler)uses a gasket or is it a dry seal?
Cody
97 30th Anniv Camaro SS#2374~ Forged 383 w/4 bolt mains,Pro5.0,LT4KM,Pro Performance Heads(288in/216ex@.600"),GTP-6 cam,Comp. Magnum 1.6" RR's,Chromoley Pushrods,Edelbrock Double Roller,Meziere,52MM BBK TB,Hooker LT's w/ Custom 3" Y-pipe,Borla,SLP CAI,30# Inj.,OBD1PCM,SPEC Stage 3 Carbon
Old Setup Dyno #'s on Stock Bottem-End NA~ 370rwhp/353rwtq
My SS
E.T.F.A East Texas F-Body Assoc.
-Kiss my SS-
Old Aug 11, 2002 | 10:49 PM
RichJ's Avatar
Post
At your advice (and the advice of others), I think I'm going to pull my oil cooler to be safe. What exactly do you need to buy? Any part numbers would be great.
Thanks,
Rich
Old Aug 11, 2002 | 11:02 PM
97 RedSS's Avatar
Post
You need these 2 bolts..Part # is 3951644
You need this Bypass hose Part # 10197675
There ya go..
Can someone answer my question now
Cody
Old Aug 12, 2002 | 12:21 AM
97 RedSS's Avatar
Post
ttt
Old Aug 12, 2002 | 06:30 AM
ROCKN SS's Avatar
Post
It's been awhile, but I don't remember a gasket.
Old Mar 9, 2003 | 11:17 AM
Bryan 94 Z28's Avatar
OK, I'm bringing this one up from the dead, cause I need an answer too.
Anyone else have any solid info on whether there's a gasket needed there?
Old Jun 10, 2003 | 02:35 PM
Rodrigues's Avatar
Up from dead again.
Old Jun 10, 2003 | 02:46 PM
4drLT4's Avatar
It uses a gasket AND an o'ring....
Old Jun 10, 2003 | 02:58 PM
Rodrigues's Avatar
If there is no oil cooler, I dont see a part that goes between the oil filter adapter and the block. I do however see a seal that goes between the oil filter adapter and the oil cooler. There are also two o rings that go on the coolant lines connecting to the oil cooler. If there is no oil cooler however, I dont think that the gasket or O rings can be used.
Old Jun 10, 2003 | 04:59 PM
4drLT4's Avatar
If you go to the dealer, and ask them for a gasket for an oil filter adapter...they will provide you with a round paper gasket, and an o'ring. I've had to **** with my adapter several times this last couple of weekends. The gasket usually sticks to the adapter so well after a few cycles, that you need to scrape the bastard off with a blade.
Old Jun 10, 2003 | 05:08 PM
Rodrigues's Avatar
Yours is leaking as well? Even with the round paper gasket? Mine is leaking from the very top of all that crap where it connects to the block. Is the oil adapter supposed to have any play on the block? I can wiggle mine but I also think thats why its leaking. A while ago I had trouble getting my oil filter off and i was pounding and stuff on it. Do you think that I might have just bent the bolts or something? What could possibly give it play if theres no rubber gaskets up there?
Old Jun 10, 2003 | 07:58 PM
97 RedSS's Avatar
I did NOT use any kind of gasket material at all and have had no leaks at all. I asked several peps about it and even went to 2 chevy dealers and they looked the adapter up and couldnt find anything on a gasket of such..
If you do have the oil cooler tho you will need the o-rings and gasket..
Cody
HectorM52
Jul 30, 2017 11:46 AM
Dmonty
Jun 2, 2015 11:19 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jul 4, 2005 05:00 PM
rod442
Aug 26, 2002 01:22 PM
