gasket help and hardware help
Old Dec 11, 2011 | 08:59 PM
Bykerboy869's Avatar
ok so im doing a 355 build and need recommendations on all the gaskets for the build. any help would be awesome i need all the gaskets needed for the engine.
i also need all the studs for the block and whatever else hardware needed to do the build.
i want to buy all the miscellaneous stuff that is need for the build so all the shop has to do is the machine work, assembly and tune.
Thanks in advance
Old Dec 12, 2011 | 05:33 AM
Guest47904's Avatar
Guest
Re: gasket help and hardware help
http://www.summitracing.com/parts/SL...1650/?rtype=10
Studs are purchased individually. Start with summit, fasteners section and follow the left drop down to where you want to end up.
Old Dec 12, 2011 | 04:35 PM
is that gasket kit have the head gaskets for a bored block or stock bore?
Old Dec 12, 2011 | 04:37 PM
and for the studs. what lengths and all do i needs?
Old Dec 12, 2011 | 05:06 PM
RUDEDOG's Avatar
Sealed Power gasket sets are made by Federal Mogul. They use felpro gaskets. The felpro 1074 head gasket holes are 4.125 and will work with stock and bored cylinders. If you are talking about head studs you would be better off using head bolts. Get some from ARP.
Old Dec 12, 2011 | 07:51 PM
do you have a parts number for the ARP head bolts?
Old Dec 12, 2011 | 08:09 PM
RamAir95TA's Avatar
134-3601 is what I like.
Old Dec 13, 2011 | 07:57 AM
Ram- that bolts kit is all the bolts ill need for the block?
Old Dec 13, 2011 | 09:40 AM
3DFORMULA's Avatar
That is just the cylinder head bolt kit. Summit sells all the ARP bolts for everything that bolts to the block. You will have spend some time going thru the list of bolts they offer for everything. It's really easy and located on the left side of the summitracing website. There may be a bolt kit that covers the entire rebuild process.
Old Dec 13, 2011 | 09:47 AM
3DFORMULA's Avatar
http://www.summitracing.com/search/B...word=ARP+bolts
check 2nd page for a full kit
Old Dec 13, 2011 | 10:02 PM
got these gaskets
http://www.summitracing.com/parts/SLP-260-1650/
these arp bolts
i got all the gaskets now, all the bolts for the engine.
i need main bearings and rod bearings and cam bearings. what are your recommendations for those?
I also see people saying get a good set of arp bolts for the rods. now if i were to get scat i-beams woould you recommend getting the arp bolts for them?
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
alliance12364
Sep 23, 2015 06:09 AM
