Gas smell inside car ???
Old Mar 27, 2004 | 03:04 PM
2fbodies2NV's Avatar
Question Gas smell inside car ???
After I've driven my TA and shut it off, a few minutes later I have a relatively strong smell of gas inside the car. I haven't had time to hunt down the problem yet, but I was hoping for some ideas as to what it could be.
Old Mar 27, 2004 | 03:05 PM
sabre81's Avatar
Evap canister took a poop maybe?
Hetfield's Avatar
Check the regulator.
Old Mar 27, 2004 | 03:14 PM
To see if it's not holding pressure ?
Old Mar 27, 2004 | 04:14 PM
Kataklysm's Avatar
I had a gas smell also, then my header broke so I just assumed it was cracked the whole time. Its possible your manifolds/headers are cracked or leaking.
Old Mar 27, 2004 | 04:15 PM
96ta(nick)'s Avatar
i just have gas sitting in my intake/TB and i dont know where it is coming from... checked the regulator and it is fine..
Old Mar 27, 2004 | 04:17 PM
Cerwin Vega Fan's Avatar
Might be an exhaust leak.
Old Mar 28, 2004 | 12:49 AM
I know it's not an exhaust leak, I just put new gaskets in the manifolds the other day when I did my head swap.
Old Mar 28, 2004 | 11:11 AM
By any chance is your engine running really rich?
Old Mar 28, 2004 | 11:26 AM
Jay-Roll's Avatar
Do you have a cutout? When I installed mine I had a really really strong smell like the car was running super super rich. Only really got a wiff after I shut the car down though. Only happened for a short time. Just an idea.
Old Mar 28, 2004 | 04:10 PM
No fuel leaks that I can find. Everything under the hood is dry. I'd have noticed it when I swapped the heads, the intake wasn't even really dirty. I don't have a cut-out either. It's really noticable when it's hot out and I have the windows all the way up. Where is the EVAP canister ? Isn't there something up in one of the wheel wells ?
Old Mar 28, 2004 | 04:15 PM
Do you have the backseats still in your car (serious question).
Old Mar 28, 2004 | 09:31 PM
Yes, the back seats are still in, why ?
Old Mar 28, 2004 | 09:34 PM
Cause when some people take out the back seats they don't patch up the holes in the bottom. That can cause a gas smell in the car.
Old Mar 28, 2004 | 09:36 PM
WayneE's Avatar
Driver's rear wheelwell. I'd bet that's your problem.
