gas ported pistons
Old Feb 13, 2006 | 10:14 PM
firebirdStud's Avatar
Lightbulb gas ported pistons
so, is it dumb to get these for a daily driver? I have a stroker, and I am ditchin the 18cc dished pistons for some mahle ones. prolly the -5cc dished. They have the power pack, and then the trick ones with gas porting. If you think about it, the reduced drag of 7 pistons at a time will free up some serious hp. So, anyone use them on a daily driver? Just curious how long they last, and if they are worth the additional money.
thanks
Cody
Old Feb 14, 2006 | 09:11 AM
Re: gas ported pistons
anyone?
Old Feb 14, 2006 | 01:41 PM
oneslowz28's Avatar
wanna sell the -18cc ones?
Old Feb 14, 2006 | 07:43 PM
sure do, pm sent.
Old Feb 14, 2006 | 08:08 PM
MachinistOne's Avatar
I don't use them on street motors.
Old Feb 14, 2006 | 08:09 PM
Why? How come they are not attractive for street use?
Old Feb 14, 2006 | 08:51 PM
1racerdude's Avatar
Common sence 'Stud-- They stop up and become less effective with mileage. They are subject to wear out the top ring before it's time,also.
Old Feb 14, 2006 | 09:16 PM
Lightbulb Re: gas ported pistons
no offence, but if it was common sense I wouldn't have asked. But, that makes sense, cuz the combustion gases slam the rind into the bore, so I would see how that would wear faster. Ok, thanks people. I guess I won't do it.
Old Feb 14, 2006 | 09:22 PM
1racerdude's Avatar
NO slam intended 'Stud.
Mindgame's Avatar
The only way to do it is to use lateral ports. Yes, there are different types of "gas" ports.
I don't believe you can really take advantage of gas ports without using a 1.0mm top & 2nd ring. With that, you need a harder ring and a vacuum pump.
Instead, I prefer to use a 1.2mm ring pack and NO vacuum pump. Quite a bit less drag and if you get the right rings, they will last till your next rebuild no problem.
-Mindgame
Old Feb 14, 2006 | 09:34 PM
1racerdude's Avatar
That "next rebuild" with a vacuum pump and thin rings,Just to run gas ports,gonna come sooner than ya think for a street car.
Old Feb 14, 2006 | 09:38 PM
Mindgame's Avatar
Ya, that's why we include disclaimers...
Instead, I prefer to use a 1.2mm ring pack. Quite a bit less drag and if you get the right rings, they will last till your next rebuild no problem.
That last part is based on personal experience & edited for clarity.
-Mindgame
Old Feb 14, 2006 | 09:49 PM
1racerdude's Avatar
That last part is based on personal experience.
-Mindgame
Mine was too.
Old Feb 14, 2006 | 10:00 PM
haha no slam felt 1racerdude!
Old Feb 14, 2006 | 10:06 PM
1racerdude's Avatar
OK good to know.
