Gas pedal or throttle body problem
Old Sep 13, 2004 | 06:47 PM
Brian89T's Avatar
I don't know if this could be a accelerator cable or just a gummed up throttle body. Sometimes when I am driving a let off the gas the car will stay at the same speed and rpms as before I let off the pedal. I can also replicate the problem in park by lightly pressing the gas pedal.
I replicated the problem with the car in park and found I was able to lift the accelerator cable arm up and felt a click as the tb fully closed.
Any suggestions??
Couple weeks ago i sprayed carb cleaner into the throttle body with it still on the car. It was fixed for a few hours.
Its a 97z, a4.
Also I don't know if this could be part of the problem but I have a code PO420 Bank 1, which is going to be warranty work by the dealer.
Brian
Old Sep 13, 2004 | 07:05 PM
944v8inDFW's Avatar
Re: Gas pedal or throttle body problem
I had something just like what you describe happen on a chevy truck. Turned ou to be the TPS. Just my 2 pennies
Old Sep 13, 2004 | 08:25 PM
Bud M's Avatar
Maybe the cable needs to be lubricated
Old Sep 16, 2004 | 06:10 PM
Brian89T's Avatar
I've tried lubricating the cable and it didn't help at all.
Old Sep 16, 2004 | 07:05 PM
OBE1 95Z28's Avatar
After I cleaned my TB, my RPMs would hang. I dipped a QTip in oil and dabbed it on the butterfly shaft where the shaft enters the body. Problem solved.
HectorM52
Jul 30, 2017 11:46 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
David Dorris
Jan 17, 2015 08:10 PM
lt1-xjs
Jan 17, 2015 07:52 PM
birdblack
Dec 30, 2014 06:59 PM
