gas pedal emergency
gas pedal emergency
Ok, so i was going to route my satellite radio cable so it's hidden instead of running through the open into the hatch, and i saw the accelerator pedal was bent a little. So, stupid me, figured it might work better if it weren't bent. So i got to "fix" it, and SNAP. So now my accelerator pedal is dangling under the dash! I called a local salvage place, and they have one, so I'll get the pedal assembly, but how do i go about installing it? Is it pretty straight forward? Any help would be apprecaited, as I don't really want to drive my car w/o a gas pedal, takes away from that performance aspect of the car :P
Nick
Nick
Re: gas pedal emergency
I figured it out.... It isn't just three bolts, I thought it was too, but the bracked holds all the brake stufftoo. So that wouldn't work or be very easy. BUT, the pedal itself has a pin on the end you can slip off and then just replaec that piece. So, a 5 min repair
And i found a better center console for my car, pedal and console $25
So, didn't end up being that bad of a day.
Thanks for the replies though, I was kinda worried at first. Worried and very pissed :P
Nick
So, didn't end up being that bad of a day.Thanks for the replies though, I was kinda worried at first. Worried and very pissed :P
Nick
WobblySausage
Oct 7, 2015 10:09 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
