gains/gearing???
Old Jan 24, 2005 | 01:13 PM
Z28Horn's Avatar
gains/gearing???
since i dont know how to put my mods in the sig, I have a 96 Camaro Z28 w/ 195,000 miles on the ticker, i have K & n cold air, ported and polished maf, trick flow elbow, pacesetter long tubes, off road y pipe, magnaflow catback, before i ran at the track w/ out any of the exahst mods, all i had done was the cold air and tb bypass and ported maf, how much of a gain should i expect w/ the new exhast set up, i went from 2 cats to zero,
My other question i how would i go about setting up my 373 gears, should i have someone else do it, calibrate the computer? im confused. my best at the track w/ a cold air and tb bypass and maf was 14.08 @ 99.98 mph. Thanks guys, hope you can help.
Old Jan 24, 2005 | 01:42 PM
FryedClutch's Avatar
Re: gains/gearing???
as for the gears i would have some one else doit unless your very patient and have very little money
i set up my 4.11 and i did a good job on it but it took 2 weeks and unless being paid i would not do it again
and for getting the comp clibrated i would send it to one of the boards resident tuners madz or pcm4less and i can tell you that with the tune in there it felt alot stronger than with the stock tune
and with the exhaust and gears i would expect to see mid 13's maybe better depending on how you drive and traction
Old Jan 24, 2005 | 01:55 PM
DonHood's Avatar
Good lord, nearly 200k miles, and it still ran a 14 flat at nearly 100 mph, with nothing more than a CAI and TB bypass?
LT1's are damn beasts.
Old Jan 24, 2005 | 02:13 PM
hotrod18_69's Avatar
Wow, 200K and still running that good. Thats impressive.
I agree with FryedCluthc have someone else install the gear, they can be very tricky for someone who has not done it before. Same goes for the PCM, get it tuned. Call up Madz or PCMforless and they'll hook you up.
Brad
Old Jan 24, 2005 | 02:38 PM
Z28Horn's Avatar
Yea, no lie i got 195 k on this beast, well maintained, 14 flat at 100, my u joints are kinda loose, its also an a4 would you recomend a stall for my 200,000 mile tranny, it still shifts good and all. IM in a pickle kinda right now. thanks guys.
Zach
Old Jan 24, 2005 | 02:44 PM
i dont do the auto thang but i hear the 2800 vigilantes are about the bes midle of the road converter you can get really efficient and also very effective i guess they drop times consistantly around .5 of a sec throw that in the mix your lookin at lower 13's
Old Jan 24, 2005 | 02:46 PM
Z28Horn's Avatar
Wow, up to 1/2 second, that would be phat, im working on the long tubes right now, kinda having some problems, nothing a couple beers cant take care of
