FYI: To everyone with stock injectors and 340+ RWHP
Old Dec 12, 2003 | 09:42 AM
  #16
LWillmann's Avatar
How exactly do you calculate the injector duty cycle?
Is it based on Pulsewidth?
Old Dec 12, 2003 | 09:53 AM
  #17
Josh-'04 GTO's Avatar
Injector sizes do not carry a horsepower-specific rating, as brake specific fuel consumption plays a factor, and that can vary from motor to motor based on the motor's efficiency. Read this link:
http://www.westechperformance.com/pa...ding/bsfc.html
Old Dec 12, 2003 | 10:06 AM
  #18
ianfromMA's Avatar
Originally posted by Brandon 95 Z28
Are there any good 36# ers out there now that bosch discontinued making theirs? I saw lucas offers 38# ers. I'll be at about 410rwhp n/a and I wanted a little breathing room for a 100-150 shot.
Brandon
wouldn't most of the shot be from nitrous anyways (caught myself from saying nawwws )
i know it mixes with gas...are you doing wet or dry? don't the wet shots have their own injectors or something?
Old Dec 12, 2003 | 10:09 AM
  #19
Wet kits have a separate solenoid and orifice to run the fuel in before being mixed with the nitrous at the nozzle. Horsepower added by a wet nitrous setup would have no bearing on injector sizing. It would, however, have an effect on fuel line/fuel pump sizing.
Old Dec 12, 2003 | 03:26 PM
  #20
FastZinTennessee's Avatar
Wouldn't it depend also on what kind of tranny you have? All other things being equal I'd say you would be ok with 15-20 rwhp more in a manual over an auto because of driveline losses, that is if you are giving a rwhp cutoff point for stock injectors.
Old Dec 12, 2003 | 03:34 PM
  #21
scoobysnax83's Avatar
Wo, weaving in and out of the topic here
I have one more question to add to the jumble. Wouldn't increasing fuel pressure lower load on the injectors? Just a thought. I know there is a limit to this approach, but it would seem to help your 100% duty cycle problem for a temp fix...
Old Dec 12, 2003 | 03:45 PM
  #22
Yep. Bumping up the fuel pressure increases the amount of fuel that can be pushed through at the same injector pulsewidth time.
Old Dec 12, 2003 | 05:28 PM
  #23
llafro's Avatar
True, but only to a point. Beyond a certain fuel pressure, the injector won't be able to close fully after opening. It could stick partially open and leave you with the same situation as a maxed out injector (i.e. going dangerously lean).
I've said it before here, but WHY are people willing to spend thousands on parts only to skimp on $200 worth of injectors? It just doesn't make sense in the least.
BRAD
Old Dec 12, 2003 | 05:35 PM
  #24
BRAD
Good point you've brought up I totally overlooked the problem with a Fuel Injector not being able to close. I am a firm believer in doing things the right way as well....
Old Dec 12, 2003 | 05:55 PM
  #25
Buttercup's Avatar
I was maxing out my stockers. I don't have a dyno slip but I'm only trapping 113 mph. This is at 3000ft DA, hot, and some other small problems so I can't imagine how it would've turned out in good weather
FPR's cost money too, I'd rather just spend that cash on a real solution. With everyone here willing to stretch the fuel system past its limits it's no wonder the blower guys go through engines like candy
I went straight up to 42 lb Lucas injectors when Racetronix was having a sale. After just a small amount of tuning the car behaves just as well as with the stock 24lb Multecs and I have LOTS of headroom I wouldn't go much higher than this size for high impedence injectors though. If I'm going through the trouble and money of injectors I would want to make sure, at the very least, it's under 80% DC. I don't like seeing over 85% if I can help it.
Old Dec 12, 2003 | 06:16 PM
  #26
BRAD
That would only be in cases where the pressure was bumped WAY over stock. In other words, 60+ psi, or 20+ over stock, which shouldn't be done. I totally agree that you should size the correct injectors for the engine, however, a few psi increase would do no harm, and could provide a margin of safety in a pinch.
All this goes back to my original point that there is no concrete horsepower-to-injector flow rule. There are guidelines, but the actual injector size will differ from engine to engine. Pretty much all comes down to A/F ratio and duty cycle desired.
Old Dec 13, 2003 | 07:58 AM
  #27
LWillmann's Avatar
Question
So can someone explain how to calculate injector duty cycle?
Old Dec 13, 2003 | 08:07 AM
  #28
Brent94Z's Avatar
Super Moderator
Good info! I've got stock injectors and running most of the time 380 something RWP with a max of 399 rwhp. Car runs 115 mph in the 1/4 full weight. I'm sure mine are maxed out as well but I keep a close eye on the Scanmaster and it doesn't go lean on me.
I wonder why such the large discrepancy between engines? Hmm???
Old Dec 13, 2003 | 08:46 AM
  #29
Brent,
I posted a link earlier in this thread that solves some of that question. Brake specific fuel consumption will vary from motor-to-motor based on fuel quality, combustion chamber work, and tuning to the engines powerband. All this alters a motors efficiency, changing the amount of fuel needed to get to the same A/F ratio as a different motor.
Old Dec 13, 2003 | 08:54 AM
  #30
Brent94Z's Avatar
Super Moderator
Originally posted by Josh-'97 WS6
Brent,
Yeah, I saw that and that's why I mentioned "large" in my reply. I wouldn't think one engine could be that much more efficient than another? I will check out that link though. Thanks!!!
