Fuse questions...low/high headlights on the same fuse?
Old Nov 24, 2004 | 03:24 PM
ShelbyZ28's Avatar
I came home last night and my headlights worked fine. A couple hours later I started out to go to the store and my low headlights didn't work. Everything else works fine. Interior lights, tail lights, high beams, etc. Are the lows on a different fuse than the high headlights? I find it almost impossible that my two low headlights burned out at the same time. Also where is the fuse for the headlight(s), in the engine or in the interior? Thanks in advance.
Bryan
Old Nov 24, 2004 | 03:34 PM
radarb8's Avatar
Re: Fuse questions...low/high headlights on the same fuse?
there is no fuse on head lights there is a braker in the headlight switch and the only way to fix it is to replace the switch
Old Nov 24, 2004 | 03:41 PM
ShelbyZ28's Avatar
So if the high beams work then the switch isn't the problem? I guess both of my low beams went out then.
Old Nov 25, 2004 | 10:19 AM
radarb8's Avatar
I have worked on cars where the dim lights will go on and off but the brights works ok and also cars that ether high or low beams work only so I would take one of your not working headlights out and hook battery power to the termanals on the back of the light and if it works I would replace the headlight switch
Jeff1904
Jun 5, 2016 05:00 PM
autoxr166
Sep 25, 2015 04:21 PM
Greg88
Sep 20, 2015 07:14 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
jackpawt883
Sep 10, 2015 08:53 PM
