Full LE2 package + 125 shot + STOCK bottom end?! ---
Old Sep 14, 2006 | 05:45 PM
AlwaysCode390's Avatar
Exclamation Full LE2 package + 125 shot + STOCK bottom end?! ---
I am about to order a FULL LE2 package ( heads, cam, ported intake) and want to use my 125 shot of n20 ... BUT I still have the stock bottom end. I have EVERY supported mod everywhere else. Will I be fine, or is just the LE2 stuff on a stock bottom pushing my luck? Opinions are appreciated, THANKS ---
Old Sep 14, 2006 | 05:56 PM
CamaroSS30thAnn's Avatar
Re: Full LE2 package + 125 shot + STOCK bottom end?! ---
i would have to say ur pushing it. Ur bottom end will hold but for how long is teh question
Old Sep 14, 2006 | 05:58 PM
CamaroBoy96Z28's Avatar
I think you'll be fine. Dont go crazy with the spray and the bottom end should hold up.
Old Sep 14, 2006 | 06:11 PM
bombebomb's Avatar
Id say your pushing it aswell, sure it will hold up but how long, like camaro ss said.
Old Sep 14, 2006 | 06:38 PM
CrazyLT1's Avatar
I think thats really pushing it!! The LE2 on its own is about the limits of the stock bottom end
Old Sep 14, 2006 | 07:04 PM
speed_demon24's Avatar
I'm a heads/cam car on a 125 shot too, if it blows up I'll let you know.
Old Sep 14, 2006 | 07:13 PM
2000GTP's Avatar
I would keep the idea of a motor rebuild on the back of your mind. As long as you are getting enough fuel, I can see it lasting awhile.
Old Sep 14, 2006 | 08:19 PM
ulakovic22's Avatar
You're pushing it. The LE2 on a stock bottom end is what I consider the limit just because of the rpm's you'll be running and to add a 125 shot on top of that might blow your motor.
Old Sep 14, 2006 | 10:54 PM
Eddie Z-28's Avatar
How many miles are on it? I'm going to be running a similar setup next year but have a rebuilt 355.
Old Sep 15, 2006 | 01:58 AM
blackz97's Avatar
Yeah thats pushing it in my book. I would be worried about those stock pistons and rods. If you had ARP hardware in the rods, forged pistons, and main studs then you might be a little more safe.
Steve
Old Sep 15, 2006 | 06:32 AM
PoorMan's Avatar
Do a 50 shot.
Old Sep 15, 2006 | 08:14 AM
Javier97Z28's Avatar
Moderator
It's pushing it, but I'd do it, as long as I have a budget for a built shortblock just in case.
Old Sep 15, 2006 | 12:30 PM
Eddie Z-28's Avatar
Steve
I'm good.
Old Sep 15, 2006 | 07:03 PM
The car is SUPPOSEDLY a 355 rebuilt 20K miles ago, but I cant seem to trust what the guy has said about other mods, so the odometer says 130,000, lol.
Maybe I should just go with a 75 shot, and rejet to the 125 after I get a full rebuild? Its the ZEX dry kit and it only comes on WOT, and uses an electronic fuel management box to control everything so it should be solid.
THANKS AGAIN ---
Old Sep 15, 2006 | 10:08 PM
brokeTA's Avatar
THANKS AGAIN ---
You will need a good sized injector to run a dry kit on that setup. Your injectors will be close to being maxed on motor alone.
