Fuel System Test.
Old Mar 15, 2005 | 03:44 PM
95_LT1_6SPD's Avatar
Fuel System Test.
I installed a new walbro fuel pump a few days ago. I want to test the system before i put the rear end and exhaust back in. I have the intake manifold on an the fuel system all hooked up. None of the other sensors are plugged in tho, as its still being re-assembled from my cam swap. Can i just put the battery in and turn the key to on to see if it pressurizes. or could this cause problems with nothing else being hooked up.
Old Mar 15, 2005 | 04:50 PM
Re: Fuel System Test.
As long as the fuel system is closed, there should be no problem pressurizing it.
Old Mar 15, 2005 | 04:57 PM
Thats what i figured, i just want to make sure the pump works, and there are no leaks in the system.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
95maroboi
Jun 7, 2015 12:18 PM
Jul 4, 2005 05:00 PM
