fuel rail removal
Old May 16, 2005 | 03:08 PM
Feenix's Avatar
fuel rail removal
im in the middle of swapping my SVO injectors in and the rails are unbolted and the vac line removed from the FPR. They have play but wont move, I assume its the o rings seated in there pretty good, well i tried prying with a screwdriver at the crossover pipe and all it did was put a slight grove in my cross over pipe, there is no damage just started denting the pipe a lil bit will this be ok, either way the injectors are still seated and wont come out, I need help.
Old May 16, 2005 | 03:17 PM
madwolf's Avatar
Re: fuel rail removal
If you removed the 4 top bolts, it should come out. You will still need to pry it out, but try to do it on the rail instead, not on the tube. (still do it through the front crossover tube channel though)
Make sure to put a little oil on the o-rings before you put them back in. (also inspect and replace if necessary)
Old May 16, 2005 | 05:33 PM
Feenix's Avatar
yep thanks I got em in, car runs great, it even fixed my hard start problem, man those old injectors looked like hell!!! Well the car runs smooth and im enjoying the results so far, only took it on one test run, but im already happy cause the hard start seems to have vanished after letting it sit after the initial start up which did have a hard start of course but after letting it sit for a hour or so it started right up waaay better than ever before, like it was brand new again. Thanks for the help and tune Ion.
HectorM52
Jul 30, 2017 11:46 AM
dfarr67
Apr 10, 2015 07:44 PM
4586
Feb 13, 2015 09:16 AM
birdblack
Dec 30, 2014 06:59 PM
Jul 4, 2005 05:00 PM
