fuel pump question
How much hp can the airtek fuel pump support brand new out of the box? I'm buying a set of le3 heads, 1.6 rr, cc306 cam, 11.5 to 1 , 355 shortblock. Have all boltons as well with 42#, injectors.
Re: fuel pump question
What's it rated at in LPH?
Your typical Walbro 255 is usually good for MOST N/A applications. I have a Walbro 255 on my car and have no pressure drop at WOT with 42# injectors. Your setup is milder so I wouldn't be concerned as long as it has the same flow characteristics as the popular Walbro 255. |
Do you possibly mean "Airtex"?
The Airtex online catalog has very little info about the pump (#E3908), at least if you put 93 Camaro 5.7L into the parts lookup. http://www.showmetheparts.com/airtex/ |
| All times are GMT -5. The time now is 04:51 AM. |
