Fuel pump change now flames under car!!!
Old May 18, 2003 | 09:43 AM
begysz28's Avatar
Help. I changed my fuel pump b\c the pressure was low. Now the pressure is back up but when I rev the engine im shooting out fire ***** from under the car. I had to put the hoses on wrong. I had no clue what to do with the ones by the filler neck. Anyone have any advice. I really dont want to blow the car up with me in it.
Old May 18, 2003 | 09:46 AM
94FlamdS10Blazr's Avatar
you kinda need to be more speficic about where they are coming from. The tank, exhaust, what?
Old May 18, 2003 | 09:47 AM
begysz28's Avatar
Right before the exhaust bends over the axle. But they shoot past the tank
Old May 18, 2003 | 10:05 AM
thewinner's Avatar
it obvious that there is a leak of fuel onto the exhaust pipe, so check under there for fuel leaks. I mena thats the only thing that could really ignite fuel uinder there
Old May 18, 2003 | 10:11 AM
begysz28's Avatar
Yeah I figured that its a leak but I cant find where. The only hoses that I had trouble placing were the hoses by the filler neck. There is a canister there and 2 hoses. Only 1 hose can go to the canister. I was hoping that someone had experience changing the pump and maybe had a diagram or directions as to where the hoses go.
Old May 19, 2003 | 07:10 AM
begysz28's Avatar
Any help would be great. I would like to be able to drive my car again.
Old May 19, 2003 | 08:15 AM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
grab a hose, hose off the exhuast. then try again.... maybe gasoline just spilled on there...
Old May 19, 2003 | 08:29 AM
Dave C. '97 Z28's Avatar
uhhh...
Is it just me, or does this whole problem seem extremely dangerous??
You need to find the problem before you start that car again. Get under there and have a friend turn the key to run, but not start it. See if you can see fuel leaking out or something else...maybe an electrical short sparking and igniting the gas or something.
But just be careful....you don't want to mess around with gas like that! There is no "reset button" if you blow yourself up, or more importantly...that Camaro.
-Dave C. '97 Z28
Old May 19, 2003 | 08:38 AM
begysz28's Avatar
Yeah im a little worried about the whole blowing up thing. Plus my friend that always works on the car with me ran like hell when he saw the flames so I doubt hell be back. Ill have do get my little brother to help out, he has no clue whats going on.
Does anyone have any advice about the hoses by the filler neck?
Old May 19, 2003 | 08:57 AM
If you had your lines hooked up wrong, you may have pumped gasoline into your charcoal cannister that's beside your filler neck. If that happened, I would try to remove that and drain it somehow. Just be careful because gasoline vapor is extremely flamable.
-Dave C. '97 Z28
Old May 19, 2003 | 10:20 AM
All_Z_Way's Avatar
Re: uhhh...
WOW... I am scared just reading this. Make sure you find the problem before you ever start your car again.
For that matter...disconnect that battery now.
This reminds me of the story about the guy that had a shop put in a new fuel pump and something was messed up and it blew up with him driving and killed the owner.
So be careful.
Old May 19, 2003 | 10:22 AM
treyZ28's Avatar
if its going to leak, it will do it when it primes...
just go from off to on (w/o startng it) a few times and look for gas again
Old May 19, 2003 | 11:08 AM
begysz28's Avatar
thanks guys. Hopefully you hear form me again if not youll read about it in the news...
Old May 19, 2003 | 12:59 PM
96 WS6's Avatar
Man all I can say is may the force be with you.
Old May 19, 2003 | 01:14 PM
anasazi's Avatar
GET PICTURES!!!
