Fuel Problem...'93 Regulator?
Old Jul 24, 2009 | 12:00 PM
JamesZ28's Avatar
Ok so I recently finished my cam and heads swap. Basically I got the LE2 heads with the 226/230 Cam. He also ported my intake. Anyway we got it running using a tune from pcmforless. It seemed fine for about the first 1000 miles. It would pull hard to the rev limiter. Then I was driving it one day and noticed it started spark knocking at about 6k. It did it every time for a while. Also for the my fuel system I'm running a walbro 255 with racetronix 37# injectors. So I figured my fuel system was fine. We put it on a dyno and sure enough it was leaning out. Thing is it was lean all the way through the rpm's. Even at cruising speed. So we figured it was the tune. I sent the tune back and they readjusted it using the a/f graphs from the dyno and sent it back. I took the car out and it's acting the exact same! What's even weirder? Sometimes it spark knocks and sometimes it doesn't. It doesn't seem to have a rhyme or reason either. Just random. We were thinking it could be my fuel pressure regulator. It's a stock '93 regulator with around 127k on it. Could that be the problem? Thanks
Old Jul 24, 2009 | 12:15 PM
n2ceptor's Avatar
Have you check the pressure reading at the schader valve on the fuel rail???
Old Jul 24, 2009 | 07:20 PM
JamesZ28's Avatar
Yea. Not sure exactly what the reading was, but I know it was "normal" but it tended to bounce around. It wouldn't even out until around 3k I think which apparently is not normal.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
z28cam1993
May 29, 2015 10:17 PM
z28cam1993
May 20, 2015 10:27 PM
kaoticcamaross
Feb 17, 2015 03:13 PM
