Fuel lines for LT1
Old Apr 29, 2009 | 10:40 PM
revolution79z28's Avatar
Fuel lines for LT1
I have to replace my intake manifold gaskets to stop the dreaded oil leak and I'm wondering about the fuel lines. A Haynes book says that a special tool is required but can they be disconnected without the tool? Any input will be well appreciated and I will be working on it tommorow evening when I get home from work. I will try to take pictures for those who want to see what the top end of a 176,000 mile LT1 looks like. Thanks guys.
Old Apr 30, 2009 | 08:21 AM
lr383's Avatar
Go to any parts house they will have sell you the tool you need.
Old Apr 30, 2009 | 08:48 AM
user 647483's Avatar
http://www.shbox.com/1/quick_connect.jpg
looks like this
or this
Old Apr 30, 2009 | 11:17 AM
Thanks for the help. That's what I needed to know.
Old Apr 30, 2009 | 11:38 AM
bombebomb's Avatar
Can also look like this
Old Apr 30, 2009 | 12:28 PM
DAVE00's Avatar
Just go to your local autoparts store and you can get a pack of all the sizes for like $5. They're really cheap and good to have anyway incase you ever need em again.
Old Apr 30, 2009 | 09:56 PM
You don't even need to release the fuel lines. Just release the clamp that holds the two hard lines to the bracket on the bolt on the intake manifold, remove the 4 bolts that hold the rails on, remove the big plastic clip that holds the fuel line bundle to the throttle linkage cover, and lift the rails off with the lines intact, and flip it back on the windshield out of the way.
Old May 1, 2009 | 08:15 AM
mudbone's Avatar
How do you bleed off pressure before removing the lines? I need to replace my fuel line cover.
Old May 1, 2009 | 08:17 AM
DAVE00's Avatar
Remove your gas cap to relieve pressure in the tank and then depress the schrader valve on the back of the fuel rail (kinda like a tire valve) press the middle gently with a small screwdriver and have a towl covering it to prevent gas from dripping or spraying.
Old May 1, 2009 | 08:34 AM
mudbone's Avatar
Thanks!
Old May 4, 2009 | 10:55 PM
Well I forgot to grab the camera before I traveled to the shop so I didn't get any pictures but everything looked really good under the intake as far as I could see. The pushrods were tight and the valley was pretty clean. I just wish I had the money to rebuild the motor totally. But thanks for all of your help, I really appreciate it and the whole job took about 6 hours, thats doing everything by myself and no more dreaded intake oil leak.
Old May 16, 2009 | 12:32 PM
mudbone's Avatar
I am struggling terribly to get the quick disconnect uncoupled. I've just about scraped all the skin off my right forearm on the cowl seal area I bought the assortment pack of tools pictured earlier in this thread, but I cannot get the darn thing to release. Any tips?
Old May 16, 2009 | 12:55 PM
RamAir95TA's Avatar
Depending on whether or not they have been off before, it may take some effort. Make sure you're pressing evenly and using the right size for the right fuel line.
Old May 16, 2009 | 01:22 PM
Does this help (courtesy of Shoebox):
http://shbox.com/1/quick_connect.jpg
Are you keeping the tool in place, while trying to pull the lines apart?
Old May 16, 2009 | 07:05 PM
mudbone's Avatar
Shoebox did help. Based on his drawing, I went back to town and exchanged the plastic "tools" for an aluminum device that was much more substantial. Both line came off with ease.
Then of course, I could not slip the second line through the fuel line cover -- no matter how hard I tried. I even got a extra set of hands with my son. We were kinking the plastic fuel lines and got pretty nervous. We finally split the cover from the existing slit to the rear and snapped it over the two fuel lines.
How in the world are you supposed to slip that cover over the fuel lines anyway?
