Fuel Line Questions 94 LT1
Old Sep 12, 2011 | 02:45 PM
LT1CST's Avatar
I'm putting my 94 Z28 back together and I was wondering if someone can suggest how to remount the fuel lines to the intake fuel rail. I cut the lines where the rails hook up when I pulled the last motor. Do I really need to get new LINES? or can I mount the ones that I cut someone how?
Chris
Old Sep 12, 2011 | 02:48 PM
Bersaglieri's Avatar
Re: Fuel Line Questions 94 LT1
They make a tool to disconnect them, I'm not sure why you cut them. I suppose you could buy some hose clamps and it would work...maybe double them up past the shoulder on the hard line hookup.
-Dustin-
RamAir95TA's Avatar
I suppose the obvious question is why did you cut them up in the first place?
Speed Inc. sells a braided kit that's plug and play - that'd be my first choice.
Old Sep 12, 2011 | 03:05 PM
LT1CST's Avatar
I cut them at the time because I didnt have the tool to take them off. AND I was going to go a different route with my car. Going back to the question in hand, Thank you both for the suggeston. Ill check up on speed inc. or possible hose clamp them up.
Chris
Old Sep 12, 2011 | 04:48 PM
The kit from GM with the 3 lines is relatively cheap. $16.63 wholesale.
GM PART # 10258441
Old Sep 12, 2011 | 05:04 PM
GM PART # 10258441
$16 lines > hose clamps
Good call shoebox.
-Dustin-
Feffman
Oct 9, 2015 05:42 AM
cmdeshon
Dec 27, 2014 10:06 AM
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
