Fuel Leak
Old Apr 21, 2008 | 04:37 PM
yy's Avatar
yy
Fuel Leak
I hope this is not a stupid question but oh well.
I noticed that I was getting some fuel leakage behind the intake manifold.
It appears that it is coming from the bleeder valve on the rear side of the fuel rails. The valve looks like a tire stem valve and it is leaking from there.
Is there supposed to be a cap on the valve? Will simply putting a cap on the valve solve the problem or should I look to getting the valve repaired. Thanks.
Old Apr 21, 2008 | 04:47 PM
mdacton's Avatar
take the valve out and put a new one in...its same as a tire valve.
Fuel will spray out.....
Old Apr 21, 2008 | 05:12 PM
2000GTP's Avatar
If you are leaking fuel out of that valve, putting the cap back on won't solve the problem, but to answer your question, there is a cap from the factory on there. Do as Mdacton suggested and replace the valve core.
Old Apr 21, 2008 | 09:26 PM
yy's Avatar
yy
Thanks, I went ahead and put in a new valve core. I bought a pack of four from Autozone for only $1.99 and the tool was the same price.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
ChrisFrez
Feb 22, 2015 08:47 AM
Alex Barnes
Jan 24, 2015 10:21 PM
Jessie4tin
Jan 7, 2015 08:53 AM
blac94Z
Nov 24, 2014 07:12 PM
