Are fuel injectors universal?
Old Feb 23, 2005 | 05:23 PM
Beyonce Knowles's Avatar
Would injectors labled as "Ford" work on an LT1? Seems like they are all the same.
Old Feb 23, 2005 | 07:18 PM
The Cartel's Avatar
Re: Are fuel injectors universal?
Well, yes and no.... The injectors will plug in your electrical clips, but not all will hook to your fuel rail metal clips. Which is only a problem when the injectors are a little shorter such as an ls1 injector. I run SVO 30lb in one of my LT1's with out the metal clips and it fits fine and there is no chance of them blowing ouy and leaking... You can always dremmel the injector to make the metal clips slide on though... Hope that's not to complicated for you... You do know, you'll need to tune the computer if you change size's though...
Old Feb 23, 2005 | 07:35 PM
Yep, I'm camming it, so it'll be getting a tune.
Old Feb 23, 2005 | 08:24 PM
LqMth's Avatar
I have *cough cough* Ford motorsports 42 lb injectors.
AdsoYo
May 2, 2018 03:21 AM
daves91z28
3rd Gen / L98 Engine Tech
May 12, 2016 06:19 AM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
