fuel injectors???
Old Apr 6, 2006 | 08:59 PM
terrible 1's Avatar
fuel injectors???
my motor is missing really bad and i have a good deal of power loss. all the ignition is new...and just recently this problem started. so i pulled the plugs from the passenger side and checked em...covered in black powder(carbon). i moved to the driver side and noticed the first 2 were somewhat clean. so i figure its running lean in those chambers. i pulled the injectors and hooked them up to a 12 volt power and ran a presurized line with gas to it. it made a misty spray. i pulled one from the other side and it made a more concentrated stream line. could this be my problem?
Old Apr 7, 2006 | 08:48 AM
Re: fuel injectors???
From the description, I'd say the plugs with soot indicate a rich condition, and the two on the other side that were clean might indicate they are running correctly. Was there at least a light tan color to the two you thought were lean?
Old Apr 7, 2006 | 03:25 PM
terrible 1's Avatar
yes. my dad said the cleaner ones were normal and the black ones were runnin rich. i ordered new injectors from summit. stock 26lb. should i replace the plugs while im at it or should they be alright? none of the plugs were wet so they all were firing.
Old Apr 9, 2006 | 11:48 AM
terrible 1's Avatar
ttt
Old Apr 9, 2006 | 12:58 PM
You're running rich on multiple cylinders. Not necessarily an injector problem. Could be caused by high fuel pressure, misfires, leaking exhaust before the O2 sensors, faulty O2 sensors, etc. I wouldn't buy a set of injectors until you diagnosed the problems.
Your stock injectors are 24#/HR, not 26.
AdsoYo
May 2, 2018 03:21 AM
daves91z28
3rd Gen / L98 Engine Tech
May 12, 2016 06:19 AM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
