Fuel injector sizing
Old Apr 2, 2004 | 12:53 PM
My Red 93Z-28's Avatar
Question Fuel injector sizing
i'm building a 355 LT4 with hotcam, LT's, y-pipe, CAI, 160* Thermostat, Crane HI-6 ignition, and a 58 mm TB, will SVO 24lb injectors work, or do I need to go bigger?
Old Apr 2, 2004 | 12:59 PM
RE AND CHERYL's Avatar
Cool
You could get by with the stock injectors as long as you don't plan any head work. If you port the heads though, I would use 30lb injectors.
Looking at the list, that 58mm throttle body is way too big for your setup. A 58mm throttle body will flow about 850CFM, which your setup will never come anywhere near. Even with ported heads a better choice would be 52mm.
Old Apr 2, 2004 | 01:10 PM
The stock 22-lb injectors will work with that???
I figured I would at least have to go to 24-lb
Old Apr 2, 2004 | 01:23 PM
I already bought the TB, but figured I might port heads/intake out later and get a bigger cam, and possibly a stroker, but for now just a 355.
AdsoYo
May 2, 2018 03:21 AM
HectorM52
Jul 30, 2017 11:46 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
