Fuel Injector installation
Old Feb 25, 2004 | 05:11 PM
Vendetta's Avatar
How difficult will it be to swap out an FMU w/ stock 24 lbers for 42 lb SVO injectors? I didn't install the FMU myself. Will it be that difficult? Is there a good write-up on fuel injector instals anywhere?
Old Feb 25, 2004 | 06:02 PM
Vendetta's Avatar
ttt
Old Feb 25, 2004 | 06:06 PM
gtheftz28's Avatar
what is ttt?
Old Feb 25, 2004 | 06:07 PM
Vendetta's Avatar
Originally posted by gtheftz28
what is ttt?
"to the top" puts your post to the top of the forum when you want a response.
Old Mar 1, 2004 | 02:05 PM
Vendetta's Avatar
Nobody?
Old Mar 1, 2004 | 02:13 PM
Aaronh's Avatar
They are easy to install, but you will need your ecm reprogrammed for them.
Aaron
Old Mar 1, 2004 | 02:32 PM
30thannZ28's Avatar
The injectors are not difficult to install. I did mine when the heads and intake manifold were off. It was not a fun install (very redundant) but easy nevertheless. It takes about 30-45 minutes. All you do is slide them off the rail once you unbolt it and then undo the clips, put the new ones on and redo the clips. easy!
***edit***you need your ECU reprogrammed
Old Mar 1, 2004 | 03:35 PM
Vendetta's Avatar
Yes, the reason for the 42 lbers is due to a reprogrammed pcm...
thanks guys
Old Mar 1, 2004 | 04:02 PM
ChevyIron's Avatar
If you have a compressure blow what ever dirt that is around the injectors.Also be carefull with the clips very easy to drop and lose.I didnt reuse the clips that go the intake because they are a pita and you dont relly need them the bolts holding down the fuel rail want let them go anywhere.Goodluck with it
Old Mar 15, 2004 | 04:54 PM
Vendetta's Avatar
okay I unbolted the rails and I took the clips off the injectors... how do I get the injectors out? Do the rails come off? Can you tell I've never done injectors before (lol)?
Old Mar 15, 2004 | 05:42 PM
The Cartel's Avatar
Thumbs up
Yea injectors will come up with the fuel rail. Remember to take off the vacuum line on the fuel pressure regulator, also remove your gas cap to take off system pressure. You'll need to get fuel line disconnects to or you'll never get those off.hope that helps
Old Mar 15, 2004 | 06:48 PM
ChevyIron's Avatar
Just pull them up they have that rubber grommet on the end of them that makes a tight seal with some elbow grease you shoulkd be able to pull out the injectors.
Old Mar 15, 2004 | 07:06 PM
Vendetta's Avatar
I see, thanks much. I didn't really know what I was doing so I didn't want to break anything. I'll yank the bastards up tomorrow.
AdsoYo
May 2, 2018 03:21 AM
Alex Barnes
Jan 24, 2015 10:21 PM
Jul 4, 2005 05:00 PM
Wilson
Jul 21, 2002 05:08 PM
