fuel injector?
Old May 23, 2011 | 04:11 AM
macsz28's Avatar
fuel injector?
Does anybody know the part number for 30lb fuel injectors to fit a 1997 Z28?
And whats the best plce to order them? or does anybody here have some for sale? Thanks!!!!
Old May 23, 2011 | 05:23 AM
Guest47904's Avatar
Guest
Re: fuel injector?
Why would you need injectors that are only 6#s more than stock?
Old May 23, 2011 | 09:05 PM
DAVE00's Avatar
Re: fuel injector?
+1 - Clarify why you need larger injectors? Also, you do know that you can't just throw them on as you must program the PCM first for the larger size. If you truly do need larger injectors for FI or larger cam/motor then SVO 30's (red top) are a good and popular choice.
Old May 23, 2011 | 09:31 PM
henryz28's Avatar
Re: fuel injector?
What they said why new injectors? If you just need replacement stock injectors I can sell you a set off of my 96 z28 cheap.
Old May 24, 2011 | 12:40 AM
macsz28's Avatar
Re: fuel injector?
I just had my heads ported from Lloyd Elliott and I have a cc503 cam... I was told that I needed the larger injectors... I understand about the PCM... I'm getting a tune as soon as I get the heads put back on
Old May 24, 2011 | 12:41 AM
macsz28's Avatar
Re: fuel injector?
I guess I should of said I have the LE2 heads from Lloyd
Old May 24, 2011 | 08:46 AM
DAVE00's Avatar
Re: fuel injector?
Make sure to add your mods to your signature (set one up) as this is how the rest of us get information on your current setup. Since you have LE2's and the CC503 then SVO 30's would suit you nicely.
Old May 24, 2011 | 08:35 PM
macsz28's Avatar
Re: fuel injector?
I have tried to set up a sig. once before... but since i usually work about 12-14 hours daily I dont have much time... plus I couldnt figure it out the last time i tried....
Old May 24, 2011 | 08:49 PM
raulz28's Avatar
From: 5 minutes from the warzone in mexico(south texas)
Re: fuel injector?
Just click User CP and then click edit signature
AdsoYo
May 2, 2018 03:21 AM
daves91z28
3rd Gen / L98 Engine Tech
May 12, 2016 06:19 AM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
