frustrated and need help
Old Aug 15, 2011 | 12:09 AM
  #16
97WS6SCharged's Avatar
Re: frustrated and need help
The weep hole is on the back/bottom of the pump. What you have pictured is one of the bleeder screws which looks like it has broken off.
Old Aug 15, 2011 | 12:20 AM
  #17
jit11375's Avatar
i will put the picture up shortly. bleeder screw broken off...is that gonna b a problem?
Old Aug 15, 2011 | 12:28 AM
  #18
jit11375's Avatar
hope i got it right this time
Old Aug 15, 2011 | 01:45 AM
  #19
Close enough. It's at the bottom of your pic.
http://www.digitalcorvettes.com/corv...7weephole1.JPG
You'll want to fix the bleeder screw. You should be able to get them from Napa.
Old Aug 15, 2011 | 09:15 PM
  #20
jit11375's Avatar
Old Aug 15, 2011 | 10:10 PM
  #21
ACE1252's Avatar
Given the mileage on the engine, it would be a wise preventive maintenance move to replace the water pump. I'd grab a new AC Delco unit from Summit or RockAuto.com. You can also get a remanufactured unit if you wish(it would be cheaper than a new AC Delco one).
Either way, it would be better to put one of the above on than to put the old one back on.
Old Aug 15, 2011 | 11:50 PM
  #22
jit11375's Avatar
i understand its a smart thing to change it...but ive alredy dished out a whole bunch of money on the opti and everything else so id ont really want to spend the money if i dont have to....looking at the picture can any1 tell whether or not i need to change it? it doesn't really have the tell-tale signs such as the rust or the scaling from what i can see...
Old Aug 16, 2011 | 04:54 AM
  #23
Guest47904's Avatar
Guest
Did you have the seals on the timing cover changed ?
Old Aug 16, 2011 | 07:13 AM
  #24
A little discoloration around the weep hole is normal. What you can't tell from a picture is how smoothly and quietly the w/p turns when you spin it by hand. It will make some noise, but if it is real rough or difficult to turn or the bearing seal on the back is loose or torn, it should be replaced. The bleeder in the fuzzy pic does not look broken to me. http://shbox.com/1/bleeders.jpg
Old Aug 16, 2011 | 11:40 AM
  #25
jit11375's Avatar
i've bought the seals and they will be replaced when the opti comes in (ordered the delphi unit off ebay for 325). i dont think my water pump "needs" to b replaced at the moment...but i'm going to look around if i find a good deal on one and if i do i'll go ahed n replace it
Old Aug 18, 2011 | 02:57 PM
  #26
jit11375's Avatar
got everything sorted out and she's running much better, i can honestly say it hasn't run like this ever...even when i first got her 6 months ago.
thanks for all your help guys !
93 RedBird
Nov 15, 2015 08:24 AM
blkWidow
May 3, 2015 08:42 AM
Bandit97
Sep 2, 2003 09:35 PM
TobyZ28
Sep 1, 2003 05:05 PM
JBirdSS
Aug 30, 2003 12:10 AM
