Front turn signal bulb replacement
Old Dec 29, 2003 | 03:52 PM
eaalto's Avatar
How the fudge do I install a replacement turn signal bulb? I'm gonna look through my owners manual to try and get some idea, but to even get into the general area I had to detach the majority of the plastic protective plates or whatever they need to be called under the front end of the car. I have a clear view/reach/accessibility of the turn signal and parking light assembly but I just can't seem to figure out what I need to do from there. Anyone here have to replace their front turn signal bulbs before?
Old Dec 29, 2003 | 03:56 PM
OBE1 95Z28's Avatar
Should be a 1/4 turn socket that comes out the back of the lense housing. Your right in that you need to pull the bottom panels for access.
Old Dec 29, 2003 | 05:06 PM
eaalto's Avatar
K turn signal installed. Once you know what to do the job is cake. Thanks for your help! The owners manual helped a bit too
stangspank
Nov 13, 2015 01:02 PM
squarehead
Jan 15, 2015 07:02 PM
Ryabut98
Sep 3, 2002 11:45 PM
vinnyxgunz
Aug 28, 2002 09:41 PM
