front, shocks or struts?
Old Mar 18, 2004 | 03:56 AM
simple's Avatar
was talking with a friend of mine and he was saying they were struts while i've always read that 4th gens used shocks up front
and could someone explain the technical difference between the 2?
Steve
Old Mar 18, 2004 | 05:50 AM
Mtrhds94Z's Avatar
4th gen's have 'coil over shocks'
Check this out:
http://web.camaross.com/forums/showt...s&pagenumber=2
specifically Injuneer Fred's 'visual aid' post
Old Mar 18, 2004 | 09:28 AM
Bud M's Avatar
I'm not at all sure but I think I read that strut setups don't use an upper a arm
Old Mar 18, 2004 | 10:01 AM
WOT's Avatar
WOT
Yup. On a strut car the top of the strut is the upper suspension attachment/pivot point. A 4th gen has shocks with an SLA (short long arm) front suspension. 3rd gens use struts.
Old Mar 18, 2004 | 07:45 PM
IrocSS85's Avatar
its called a modified strut. but it works just like a coilover shock. yes, true struts dont have an upper control arm. the strut uses a upper mount/bearing since it has to turn.
chris
Old Mar 19, 2004 | 05:09 AM
simple's Avatar
thanks guys.
i didnt think i was reading wrong
Steve
Old Mar 19, 2004 | 08:14 AM
Aside from all the previous explanations, there is nothing in the GM parts books or factory manual that calls it a strut in any way, shape or form. Call it a shock and know you are correct.
HarleyZ28
Oct 5, 2015 06:23 AM
Boss002
May 20, 2015 12:55 PM
KYWes
Apr 3, 2015 07:59 PM
Magenta_Hearts
Mar 22, 2015 02:44 PM
dbrockma
Feb 16, 2015 02:56 PM
